I'm attempting to setup a new smart proxy before upgrading my production servers to latest foreman (1.1)/puppet (3.1).
My version :
rpm -q foreman-proxy
foreman-proxy-1.1stable-1.el6.noarch
The issue I face is the following : on the foreman web page, I click on the import button for the environments… and it tells me there is no change.
When I run the rake task, I get :
rake puppet:import:puppet_classes RAILS_ENV=production --trace
** Invoke puppet:import:puppet_classes (first_time)
** Execute environment
** Execute puppet:import:puppet_classes
Evaluating possible changes to your installation
No changes detected
Still, on localhost, I can access a few things :
curl -k -H "Content-Type:application/json" -H "Accept:application/json" https://127.0.0.1:8443/puppet/environments
["dev","production"]
curl -k -H "Content-Type:application/json" -H "Accept:application/json" https://127.0.0.1:8443/puppet/environments/dev
{"paths":["/etc/puppet/envs/dev","/etc/puppet/envs/common","/usr/share/puppet/modules"],"name":"dev"}
The smart proxy runs on the same VM as the puppetmaster or foreman - and I'm using passenger.
The smart proxy is not configured with the "trusted_hosts" option of the foreman installer.
I set the log_level option to "DEBUG" in the smart proxy settings, but the only thing I constantly see is the following (no debug line) :
I, [2013-03-06T19:00:23.025567 #26971] INFO – : Initializing from Puppet config file: /etc/puppet/puppet.conf
I, [2013-03-06T19:00:23.242263 #26971] INFO – : Initializing from Puppet config file: /etc/puppet/puppet.conf
I made sure the foreman user is allowed to read the modules files, so I'm a bit lost at where to look in order to fix this ??
Any idea of how to fix the import of classes/envs ?
Thanks
