Need to customize the foreman discovery iso -> fdi-bootable-3.3.1.iso
If you do not read what I write and if you do not answer my questions then I cannot help you. Sorry.
Sure, i will follow your suggestions, now currently we could not be able to create customized ISO image please see below error while using same fdi-bootable-3.3.1.iso.
[root@hylformanproxy remaster]# cd /var/tmp/foreman/foreman-discovery-image
[root@hylformanproxy foreman-discovery-image]# ls -l
total 84
-rw-r–r-- 1 root root 718 Apr 4 10:09 00-repos-centos8.ks
-rw-r–r-- 1 root root 494 Apr 4 10:09 10-header.ks
-rw-r–r-- 1 root root 2025 Apr 4 10:09 20-packages.ks
-rw-r–r-- 1 root root 5899 Apr 4 10:09 22-discovery.ks
-rw-r–r-- 1 root root 3471 Apr 4 10:09 25-minimize.ks
-rw-r–r-- 1 root root 1582 Apr 4 10:09 anaconda-rhsm-BZ2034601.patch
drwxr-xr-x 5 root root 131 Apr 4 10:09 aux
-rwxr-xr-x 1 root root 1379 Apr 4 10:09 build-livecd
-rwxr-xr-x 1 root root 3436 Apr 4 10:09 build-livecd-root
-rwxr-xr-x 1 root root 45 Apr 4 10:09 clean-cache
drwxr-xr-x 6 root root 93 Apr 4 10:09 example_zip
-rwxr-xr-x 1 root root 74 Apr 4 10:09 extract-strings
-rw-r–r-- 1 root root 148 Apr 4 10:09 fdi-centos8.ks
-rw-r–r-- 1 root root 119 Apr 4 10:09 fdi-empty.ks
-rw-r–r-- 1 root root 18027 Apr 4 10:09 LICENSE
-rw-r–r-- 1 root root 11529 Apr 4 10:09 README.md
drwxr-xr-x 5 root root 39 Apr 4 10:09 root
[root@hylformanproxy foreman-discovery-image]# cd /var/tmp/foreman/foreman-discovery-image/aux/remaster
[root@hylformanproxy remaster]# ls -l
total 242692
-rwxr-xr-x 1 root root 3762 Apr 4 10:09 discovery-remaster
-rw-r–r-- 1 root root 248512512 Jan 4 2017 fdi-bootable-3.3.1.iso
[root@hylformanproxy remaster]# bash ./discovery-remaster fdi-bootable-3.3.1.iso “proxy.url=https://hylformanproxy.micron.com proxy.type=proxy fdi.pxauto=1”Copying contents to temporary directory…
Making hardlinks so inodes can be cached to save space…
/tmp/tmp.NZoEUZ1iO3 /var/tmp/foreman/foreman-discovery-image/aux/remaster
ln: failed to access ‘isolinux/initrd.img’: No such file or directory
ln: failed to access ‘isolinux/vmlinuz’: No such file or directory
Configuring bootloaders…
Copy grub config to the ESP image…
Can’t open /tmp/tmp.NZoEUZ1iO3/images/efiboot.img: No such file or directory
Cannot initialize ‘::’
Bad target ::EFI/BOOT/grub.cfg
Building new ISO image…
Warning: creating filesystem that does not conform to ISO-9660.
Size of boot image is 4 sectors → No emulation
4.13% done, estimate finish Tue Apr 4 11:06:20 2023
8.26% done, estimate finish Tue Apr 4 11:06:20 2023
12.40% done, estimate finish Tue Apr 4 11:06:20 2023
16.53% done, estimate finish Tue Apr 4 11:06:20 2023
20.65% done, estimate finish Tue Apr 4 11:06:20 2023
24.78% done, estimate finish Tue Apr 4 11:06:20 2023
28.92% done, estimate finish Tue Apr 4 11:06:20 2023
33.04% done, estimate finish Tue Apr 4 11:06:20 2023
37.18% done, estimate finish Tue Apr 4 11:06:20 2023
41.30% done, estimate finish Tue Apr 4 11:06:20 2023
45.44% done, estimate finish Tue Apr 4 11:06:20 2023
49.56% done, estimate finish Tue Apr 4 11:06:20 2023
53.69% done, estimate finish Tue Apr 4 11:06:20 2023
57.82% done, estimate finish Tue Apr 4 11:06:20 2023
61.95% done, estimate finish Tue Apr 4 11:06:20 2023
66.08% done, estimate finish Tue Apr 4 11:06:20 2023
70.21% done, estimate finish Tue Apr 4 11:06:20 2023
74.33% done, estimate finish Tue Apr 4 11:06:20 2023
78.47% done, estimate finish Tue Apr 4 11:06:20 2023
82.59% done, estimate finish Tue Apr 4 11:06:20 2023
86.73% done, estimate finish Tue Apr 4 11:06:20 2023
90.85% done, estimate finish Tue Apr 4 11:06:20 2023
94.99% done, estimate finish Tue Apr 4 11:06:20 2023
99.11% done, estimate finish Tue Apr 4 11:06:20 2023
Total translation table size: 6249
Total rockridge attributes bytes: 2866
Total directory bytes: 10240
Path table size(bytes): 78
Max brk space used 22000
121085 extents written (236 MB)
isohybrid: proxy.type=proxy: unable to find efi image
Inserting md5sum into iso image…
md5 = 119a2646ef01eab583417f987dd528c9
Inserting fragment md5sums into iso image…
fragmd5 = 57d7d2429b86ecec69ea41c66c393aa26f2259b62cb448328bd6892ac912
frags = 20
Setting supported flag to 0
Created: proxy.type=proxy (BIOS-only compatible)
Cleaning up temporary directory…
total 484864
-rw-r–r-- 1 root root 247982080 Apr 4 11:06 proxy.type=proxy
the git used to create customized ISO image for our environment. Please suggest me how do i modify about my proxy server name?
step1 ) GitHub - theforeman/foreman-discovery-image: Foreman discovery image live distro
cloned above one
step2 ) wget http://downloads.theforeman.org/discovery/releases/3.3/fdi-bootable-3.3.1.iso
[root@hylformanproxy image]# ls -ltr
total 242868
-rw-r–r-- 1 root root 3762 Mar 27 14:18 dis
-rw-r–r-- 1 root root 248512512 Mar 27 17:00 fdi-bootable-3.3.1.iso
-rw-r–r-- 1 root root 180009 Mar 30 14:01 discovery-remaster
[root@hylformanproxy image]# bash ./discovery-remaster fdi-bootable-3.3.1.iso “proxy.url=https://hylformanproxy.micron.com proxy.type=proxy fdi.pxauto=1”
./discovery-remaster: line 8: syntax error near unexpected token newline' ./discovery-remaster: line 8: ’
SolutionReply
Jan
srikanthm
5d
SolutionReply
srikanthm
Jan
3m
total 84
total 242692
frags = 20
total 484864
First of all, please format your console output as Preformatted text for better reading.
Second:
Please answer what you see there.
Third:
From your latest output I can (hardly see, because no preformatted text) that your discovery-remaster call seems to be buggy:
You end up with an ISO file with proxy.type=proxy as filename. So the option was not parsed correctly by bash. Please type the following line and do not copy. Look out to use correct quote characters!
bash ./discovery-remaster fdi-bootable-3.3.1.iso "proxy.url=https://hylformanproxy.micron.com proxy.type=proxy fdi.pxauto=1"
after pressing tab
total 1559656
-rwxrwxrwx 1 root root 247982080 Apr 4 11:50 fdi3.3.iso
-rw-r–r-- 1 root root 550502400 Jul 19 2022 fdi-4.1.0-24d62de.iso
-rw-r–r-- 1 root root 550502400 Apr 4 11:43 fdi.iso
/tmp/tmp.7BB54Rxghp /var/tmp/foreman/foreman-discovery-image/aux/remaster
Can’t open /tmp/tmp.7BB54Rxghp/images/efiboot.img: No such file or directory
4.13% done, estimate finish Tue Apr 4 18:11:36 2023
8.26% done, estimate finish Tue Apr 4 18:11:36 2023
12.40% done, estimate finish Tue Apr 4 18:11:36 2023
16.53% done, estimate finish Tue Apr 4 18:11:36 2023
20.65% done, estimate finish Tue Apr 4 18:11:36 2023
24.78% done, estimate finish Tue Apr 4 18:11:36 2023
28.92% done, estimate finish Tue Apr 4 18:11:36 2023
33.04% done, estimate finish Tue Apr 4 18:11:36 2023
37.18% done, estimate finish Tue Apr 4 18:11:36 2023
41.30% done, estimate finish Tue Apr 4 18:11:36 2023
45.44% done, estimate finish Tue Apr 4 18:11:36 2023
49.56% done, estimate finish Tue Apr 4 18:11:36 2023
53.69% done, estimate finish Tue Apr 4 18:11:36 2023
57.82% done, estimate finish Tue Apr 4 18:11:36 2023
61.95% done, estimate finish Tue Apr 4 18:11:36 2023
66.08% done, estimate finish Tue Apr 4 18:11:36 2023
70.21% done, estimate finish Tue Apr 4 18:11:36 2023
74.33% done, estimate finish Tue Apr 4 18:11:36 2023
78.47% done, estimate finish Tue Apr 4 18:11:36 2023
82.59% done, estimate finish Tue Apr 4 18:11:36 2023
86.73% done, estimate finish Tue Apr 4 18:11:36 2023
90.85% done, estimate finish Tue Apr 4 18:11:36 2023
94.99% done, estimate finish Tue Apr 4 18:11:36 2023
99.11% done, estimate finish Tue Apr 4 18:11:36 2023
isohybrid: fdi-bootable-3.3.1-230404_181116.iso: unable to find efi image
md5 = 96b0bb3e154864f0794b7f4e640cb329
fragmd5 = 38d85f3dded5d29caec193d8dad41f693c72affdd275276e47f478ac77b8
frags = 20
Created: fdi-bootable-3.3.1-230404_181116.iso (BIOS-only compatible)
I already provided answers to all of your issues.
Again:
Do NOT use latest version of discovery-remaster script from Github in combination with FDI v3.3.1!!!
You need use the following revision of this script: b94bf01e26be01edffc1290b8c726f2d6ecdceec
To get this revision of this file, simply do:
$ wget https://raw.githubusercontent.com/theforeman/foreman-discovery-image/b94bf01e26be01edffc1290b8c726f2d6ecdceec/aux/remaster/discovery-remaster
It is IMPORTANT that you copy the whole URL including the revision for wget!
To double check if you use correct version do:
$ sha1sum ./discovery-remaster
eaf21614913d4c10dcca5282ab8e040807324852  ./discovery-remaster
If you don’t have exactly same SHA hashsum, I give up!
If you have exactly the same SHA hashsum, run again:
$ bash ./discovery-remaster fdi-bootable-3.3.1.iso "proxy.url=https://hylformanproxy.micron.com proxy.type=proxy fdi.pxauto=1"
Upload built ISO to vSphere, set as CD-ROM and boot from it.
created new iso image using with above instruction then whie booting with ISO image which is getting error
[root@hylformanproxy remaster]# ./discovery-remaster fdi-bootable-3.3.1.iso “proxy.url=https://hylformanproxy.micron.com:9090 proxy.type=proxy fdi.pxauto=1”
/tmp/tmp.4tqXJhDqo7 /var/tmp/foreman/foreman-discovery-image/aux/remaster
Can’t open /tmp/tmp.4tqXJhDqo7/images/efiboot.img: No such file or directory
4.13% done, estimate finish Tue Apr 4 19:00:32 2023
8.26% done, estimate finish Tue Apr 4 19:00:32 2023
12.40% done, estimate finish Tue Apr 4 19:00:32 2023
16.53% done, estimate finish Tue Apr 4 19:00:32 2023
20.65% done, estimate finish Tue Apr 4 19:00:32 2023
24.78% done, estimate finish Tue Apr 4 19:00:32 2023
28.92% done, estimate finish Tue Apr 4 19:00:32 2023
33.04% done, estimate finish Tue Apr 4 19:00:32 2023
37.18% done, estimate finish Tue Apr 4 19:00:32 2023
41.30% done, estimate finish Tue Apr 4 19:00:32 2023
45.44% done, estimate finish Tue Apr 4 19:00:32 2023
49.56% done, estimate finish Tue Apr 4 19:00:32 2023
53.69% done, estimate finish Tue Apr 4 19:00:32 2023
57.82% done, estimate finish Tue Apr 4 19:00:32 2023
61.95% done, estimate finish Tue Apr 4 19:00:32 2023
66.08% done, estimate finish Tue Apr 4 19:00:32 2023
70.21% done, estimate finish Tue Apr 4 19:00:32 2023
74.33% done, estimate finish Tue Apr 4 19:00:32 2023
78.47% done, estimate finish Tue Apr 4 19:00:32 2023
82.59% done, estimate finish Tue Apr 4 19:00:32 2023
86.73% done, estimate finish Tue Apr 4 19:00:32 2023
90.85% done, estimate finish Tue Apr 4 19:00:32 2023
94.99% done, estimate finish Tue Apr 4 19:00:32 2023
99.11% done, estimate finish Tue Apr 4 19:00:32 2023
isohybrid: fdi-bootable-3.3.1-230404_190011.iso: unable to find efi image
md5 = 5032e0503d381850334ed6497c14736e
fragmd5 = b94d69f3651f4c9ee26d83a581286c81b8f3f1956a63efe56acad9a3f7d1
frags = 20
Created: fdi-bootable-3.3.1-230404_190011.iso (BIOS-only compatible)
after i have selected resend then getting successs
Please suggest me why we required to resend again to get SUCCESS state.
thank you for your help on it
yes it can be use for others above solutions.
