Trying to provision a new Rocky 9.1 system. System installs but doesnt install consumer certs and therefore no subscription-manager or updates or any of our required packages are installed.
I’ve found the issue, which is that the katello-rhsm-consumer script wants to put the scripts in /etc/rhsm/ca/katello-server-ca.crt, but the /etc/rhsm/ca directory doesn’t exist.
Creating the ca directory under /etc/rhsm and manually running the script works fine.
As a quick fix, i was hoping to be able to add a “if directory does not exist: Create it” but i’m not sure where i can make these changes so that they get implented into the consumer rpm package
katello-ca-consumer.rpm gets installed properly
foreman 3.4
katello 4.6
Latest updates installed
