Great to hear. For custom content, start here - http://www.katello.org/docs/user_guide/content/content.html
You'll note that we have a number of user guides for all the major
pieces of Katello that are recommended reading as a starting place.
Eric
On Wed, Oct 1, 2014 at 11:06 AM, wrote:
> That did the trick! Now I can see the Enable? check boxes. Thank you!
> Now, will I be able to set up other repositories? I.e, for CentOSv5 & v6
> 64-bit - are there instructions for that?
> On Wednesday, October 1, 2014 10:47:00 AM UTC-4, jsherril wrote:
>> On 10/01/2014 10:34 AM, marc....@priceline.com wrote:
>> > Where do I enter the proxy information? I'd like to try that....
>> re-run katello-installer with these options:
>> --katello-proxy-url=http://proxy.hostname.com
>> --katello-proxy-port=8080
>> --katello-proxy-password=password
>> --katello-proxy-username=username
>> omitting username and password if they are not needed. Make sure to
>> specify the full url for the proxy URL (not just the hostname)
>> Once that completes, run:
>> service foreman-tasks restart
>> and then try again.
>> -Justin
> "Foreman users" group.
> email to foreman-users+unsubscribe@googlegroups.com.
> Visit this group at http://groups.google.com/group/foreman-users.
I'm still chugging along on setting up and testing Katello/Foreman… and
now I'm trying to register a host server so that I could manage patching
the system (the purpose of using Katello as a replacement of our Satellite
server). I'm trying to register a CentOS6 64-bit system. I've created a
repository for CentOS6x86_64 and when I follow the instructions to
"Register a Content Host", I get the following error message:
[root@nw-fnx-002 ~]# subscription-manager register --org="Priceline_com"
–environment="Library"
Unable to find Subscription Manager module.
Error: cannot import name create_from_file
Any thoughts what's causing this?
Thanks.
On Wednesday, October 1, 2014 11:56:58 AM UTC-4, marc....@priceline.com wrote:
> I'm sync'ing the RedHat Packages successfuly now, But, I don't see any
> Errata data being sync'ed? I don't see an Errata check box to enable them?
>> and then try again.
>> -Justin
> and then try again.
> -Justin
> and then try again.
> -Justin
> Eric, Justin,
> --environment="Library"
> Thanks.
Hi Marc, could you confirm the versions of subscription-manager and
python-rhsm you have installed?
Also could you extract the likely stacktrace from /var/log/rhsm/rhsm.log on
the client system.
Thanks.
On Thursday, October 2, 2014 12:00:41 PM UTC-3, marc....@priceline.com wrote:
[root@nw-fnx-002 ~]# ls -tlr /var/log/rhsm/rhsm.log
-rw-r–r-- 1 root root 0 Oct 2 10:45 /var/log/rhsm/rhsm.log
Thanks!
On Thursday, October 2, 2014 11:31:33 AM UTC-4, Devan Goodwin wrote:
> On Thursday, October 2, 2014 12:00:41 PM UTC-3, marc....@priceline.com > wrote:
>> Eric, Justin,
>> I'm still chugging along on setting up and testing Katello/Foreman....
>> and now I'm trying to register a host server so that I could manage
>> patching the system (the purpose of using Katello as a replacement of our
>> Satellite server). I'm trying to register a CentOS6 64-bit system. I've
>> created a repository for CentOS6x86_64 and when I follow the instructions
>> to "Register a Content Host", I get the following error message:
>> Thanks.
> on the client system.
> Thanks.
>> On Wednesday, October 1, 2014 11:56:58 AM UTC-4, marc....@priceline.com >> wrote:
>>>> and then try again.
>>>> -Justin
> Sure Devan, here you go…
> [root@nw-fnx-002 ~]# rpm -qa | grep subscr
> subscription-manager-1.13.2-1.el6.x86_64
This version of subscription-manager requires python-rhsm >= 1.12.3, your
version is extremely old. yum/rpm would have complained about this, did
you force install some rpms or something like that?
Anyhow upgrade your python-rhsm and you should get past this.
Cheers,
Devan
On Thursday, October 2, 2014 12:40:38 PM UTC-3, marc....@priceline.com wrote:
I’m still chugging along on setting up and testing Katello/Foreman…
and now I’m trying to register a host server so that I could manage
Satellite server). I’m trying to register a CentOS6 64-bit system. I’ve
to “Register a Content Host”, I get the following error message:
[root@nw-fnx-002 ~]# subscription-manager register --org=“Priceline_com”
–environment=“Library”
Any thoughts what’s causing this?
Thanks.
And when I search for this package within Foreman for the CentOS6 x86_64
repository, that I had previously synced in Katello, that package doesn't
exist there either.
Where can I find this package (python-rhsm-1.12.3.noarch.rpm or similar)
and I'll be glad to install it!
Thanks.
Marc.
On Thursday, October 2, 2014 12:05:38 PM UTC-4, Devan Goodwin wrote:
> On Thursday, October 2, 2014 12:40:38 PM UTC-3, marc....@priceline.com > wrote:
>> Sure Devan, here you go...
> version is *extremely* old. yum/rpm would have complained about this, did
> Cheers,
> Devan
>> [root@nw-fnx-002 ~]# rpm -qa | grep python-rhsm
>> python-rhsm-0.96.4-2.1.noarch
>> That log file is empty:
>> -rw-r--r-- 1 root root *0* Oct 2 10:45 /var/log/rhsm/rhsm.log
>> Thanks!
>>> On Thursday, October 2, 2014 12:00:41 PM UTC-3, marc....@priceline.com >>> wrote:
>>>> Eric, Justin,
>>>> --org="Priceline_com" --environment="Library"
>>>> Thanks.
>>> Thanks.
>>>> On Wednesday, October 1, 2014 11:56:58 AM UTC-4, marc....@priceline.com >>>> wrote:
>>>>> any Errata data being sync'ed? I don't see an Errata check box to enable
>>>>> them?
>>>>>> and then try again.
>>>>>> -Justin
> Yes, you're correct, I had to manually install the python-rhsm package,
> because when I search for this package on the web, I found only this one:
> http://rpm.pbone.net/index.php3/stat/3/srodzaj/1/search/python-rhsm
> and when I try to upgrade the package, there aren't any available from the
> repo I'm currently connected to:
> [root@nw-fnx-002 yum.repos.d]# cat epel.repo
> [epel]
> name=Extra Packages for Enterprise Linux 6 - $basearch
> #baseurl=http://download.fedoraproject.org/pub/epel/6/$basearch
> mirrorlist=
> https://mirrors.fedoraproject.org/metalink?repo=epel-6&arch=$basearch
> failovermethod=priority
> enabled=1
> gpgcheck=1
> gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-EPEL-6
> proxy=http://nw-iwsva.corp.pcln.com:8080
> [root@nw-fnx-002 ~]# yum check-update | grep python-rhsm
> exist there either.
> Thanks.
> Marc.
–org=“Priceline_com” --environment=“Library”
Thanks.
/var/log/rhsm/rhsm.log on the client system.
That helped. I downloaded and installed the correct python-rhsm from the
link you provided (I must've missed it before). And I was able to install
the subscription-manager.
Then I was able to register this Content Host server as follows:
[root@nw-fnx-002 tmp]# subscription-manager register --org="Priceline_com"
Username: priceline
Password:
The system has been registered with ID:
1df96c83-6c3a-4af3-a56f-cded084f06d8
But, now when I go into Foreman, I can't find this server listed anywhere.
Is there another step? Where did it go?
I appreciate your help!
Marc.
On Thursday, October 2, 2014 12:57:48 PM UTC-4, Devan Goodwin wrote:
> On Thursday, October 2, 2014 1:32:42 PM UTC-3, marc....@priceline.com > wrote:
>> the repo I'm currently connected to:
>> [epel]
>> mirrorlist=
>> enabled=1
>> gpgcheck=1
>> exist there either.
>> Thanks.
>> Marc.
> It should have been in the same location you found subscription-manager,
> but the instructions here are correct:
> http://www.katello.org/docs/user_guide/content_hosts/index.html#installing-subscription-manager
> That will end up pointing you at this repo which is where we publish our
> community builds:
> https://repos.fedorapeople.org/repos/candlepin/subscription-manager/epel-6/x86_64/
> Cheers,
> Devan
>>> On Thursday, October 2, 2014 12:40:38 PM UTC-3, marc....@priceline.com >>> wrote:
>>> your version is *extremely* old. yum/rpm would have complained about this,
>>> did you force install some rpms or something like that?
>>> Cheers,
>>> Devan
>>>> Thanks!
>>>>> On Thursday, October 2, 2014 12:00:41 PM UTC-3, marc....@priceline.com >>>>> wrote:
>>>>>> Eric, Justin,
>>>>>> Katello/Foreman.... and now I'm trying to register a host server so that I
>>>>>> could manage patching the system (the purpose of using Katello as a
>>>>>> replacement of our Satellite server). I'm trying to register a CentOS6
>>>>>> 64-bit system. I've created a repository for CentOS6x86_64 and when I
>>>>>> follow the instructions to "Register a Content Host", I get the following
>>>>>> error message:
>>>>>> Thanks.
>>>>> Thanks.
>>>>>> On Wednesday, October 1, 2014 11:56:58 AM UTC-4, >>>>>> marc....@priceline.com wrote:
>>>>>>> them?
>>>>>>>> to
>>>>>>>> and then try again.
>>>>>>>> -Justin
