Looks like the the concerns for org
(Katello::Concerns::OrganizationExtensions) are not getting loaded when
I call the katello api v2. Calling this cli:
bundle exec bin/hammer -u admin -p changeme lifecycle-environment create
–organization-id DemoOrg --name TEST --prior Library
I get the following stack trace
Setting current user thread-local variable to admin
Checking params for katello/api/v2/environments/create
NoMethodError: undefined method without_deleting' for #<Class:0x00000009206490> /home/bkearney/.rvm/gems/ruby-1.9.3-p484/gems/activerecord-3.2.16/lib/active_record/dynamic_matchers.rb:55:in
method_missing'
/home/bkearney/code/katello/app/controllers/katello/api/v2/api_controller.rb:131:in
get_organization' /home/bkearney/code/katello/app/controllers/katello/api/v2/api_controller.rb:115:in
find_optional_organization'
/home/bkearney/code/katello/app/controllers/katello/api/v2/api_controller.rb:98:in
find_organization' /home/bkearney/.rvm/gems/ruby-1.9.3-p484/gems/activesupport-3.2.16/lib/active_support/callbacks.rb:520:in
block (3 levels) in
_run__1415486125253698300__process_action__840835398371412458__callbacks'
/home/bkearney/.rvm/gems/ruby-1.9.3-p484/gems/activesupport-3.2.16/lib/active_support/callbacks.rb:215:in
block in _conditional_callback_around_27341' /home/bkearney/.rvm/gems/ruby-1.9.3-p484/gems/activesupport-3.2.16/lib/active_support/callbacks.rb:326:in
around'
> From: "Bryan Kearney" <bkearney@redhat.com>
> To: "Foreman ." <foreman-dev@googlegroups.com>
> Sent: Wednesday, January 22, 2014 6:38:30 AM
> Subject: [foreman-dev] Next issue… missing methods for org
> --organization-id DemoOrg --name TEST --prior Library
> NoMethodError: undefined method without_deleting' for > #<Class:0x00000009206490> > /home/bkearney/.rvm/gems/ruby-1.9.3-p484/gems/activerecord-3.2.16/lib/active_record/dynamic_matchers.rb:55:in >
method_missing'
> get_organization' > /home/bkearney/code/katello/app/controllers/katello/api/v2/api_controller.rb:115:in >
> find_organization' > /home/bkearney/.rvm/gems/ruby-1.9.3-p484/gems/activesupport-3.2.16/lib/active_support/callbacks.rb:520:in >
block (3 levels) in
> block in _conditional_callback_around_27341' > /home/bkearney/.rvm/gems/ruby-1.9.3-p484/gems/activesupport-3.2.16/lib/active_support/callbacks.rb:326:in >
around'
> - bk
this is an issue that hasn't quite been resolved yet on the server side. it's something to do with Katello's organization being an extention of Foreman's organization. Somewhere in the call stack, the Foreman organization probably gets reloaded and Katello's organization gets skipped. Restart your Foreman/Katello server and you should ™ be fine.
----- Original Message -----
"foreman-dev" group.
I have. i think it has to do with a pre create hook.
— bk
>> To: "Foreman ."
>> Subject: [foreman-dev] Next issue... missing methods for org
>> NoMethodError: undefined method `without_deleting' for
>> `method_missing'
>> `get_organization'
>> `find_optional_organization'
>> `find_organization'
>> `block (3 levels) in
>> `block in _conditional_callback_around_27341'
>> `around'
>> - bk
> From: "Bryan Kearney" <bryan.kearney@gmail.com>
> To: foreman-dev@googlegroups.com
> Sent: Wednesday, January 22, 2014 10:18:38 AM
> Subject: Re: [foreman-dev] Next issue… missing methods for org
> >> NoMethodError: undefined method without_deleting' for > >> #<Class:0x00000009206490> > >> /home/bkearney/.rvm/gems/ruby-1.9.3-p484/gems/activerecord-3.2.16/lib/active_record/dynamic_matchers.rb:55:in > >>
method_missing'
> >> get_organization' > >> /home/bkearney/code/katello/app/controllers/katello/api/v2/api_controller.rb:115:in > >>
> >> find_organization' > >> /home/bkearney/.rvm/gems/ruby-1.9.3-p484/gems/activesupport-3.2.16/lib/active_support/callbacks.rb:520:in > >>
block (3 levels) in
> >> block in _conditional_callback_around_27341' > >> /home/bkearney/.rvm/gems/ruby-1.9.3-p484/gems/activesupport-3.2.16/lib/active_support/callbacks.rb:326:in > >>
around'
> >> - bk
> — bk
you aren't wrong. there's a
before_filter :find_organization, :only => [:index, :create, :paths]
to look up the organization when you create a system.
it boils down to this method:
def get_organization(org_id)
name/label is always unique
return Organization.without_deleting.having_name_or_label(org_id).first
end
#without_deleting is defined in app/models/katello/concerns/organization_extension.rb and "method_missing" only complains occasionally which makes me think one piece, but not all, is getting reloaded.
