I´m getting the below errors for the OpenNebula Plugin, maybe someone can
help…
*- Procedure "edit Compute Profile" => undefined method
vm_description'...(see below)* Successfully decrypted field for ForemanOne::One OpenNebula Operation FAILED: undefined method
vm_description' for
#<Fog::Compute::OpenNebula::Server:0x007f9ed81d4f38>
Rendered common/500.html.erb (4.1ms)
Completed 500 Internal Server Error in 39ms (Views: 4.9ms | ActiveRecord:
10.4ms)
NoMethodError
undefined method vm_description' for #<Fog::Compute::OpenNebula::Server:0x007f9ed81d4f38> app/models/compute_attribute.rb:26:in
pretty_vm_attrs'
app/models/compute_attribute.rb:32:in update_name' app/controllers/compute_attributes_controller.rb:10:in
create'
app/models/concerns/foreman/thread_session.rb:33:in clear_thread' lib/middleware/catch_json_parse_errors.rb:9:in
call'
- Procedure "create new host" => operator does not exist…(see below)
Unable to save
Query instance details for testhost.cesystems.at task failed with the
following error: PGError: ERROR: operator does not exist: character varying
= integer LINE 1: …D "hosts"."location_id" IN (3) AND "hosts"."uuid" = 11
LIMIT… ^ HINT: No operator matches the given name and argument type(s).
You might need to add explicit type casts. : SELECT "hosts".* FROM "hosts"
WHERE "hosts"."organization_id" IN (4) AND "hosts"."location_id" IN (3) AND
"hosts"."uuid" = 11 LIMIT 1
Package List:
Foreman Server
ruby193-rubygem-foreman_one-0.2-1.el6.noarch
ruby193-rubygem-fog-1.23.0-1.el6.noarch
ruby193-rubygem-fog-core-1.23.0-1.el6.noarch
OpenNebula Server:
opennebula-common-4.8.0-1.x86_64
opennebula-server-4.8.0-1.x86_64
opennebula-4.8.0-1.x86_64
opennebula-sunstone-4.8.0-1.x86_64
opennebula-node-kvm-4.8.0-1.x86_64
opennebula-ruby-4.8.0-1.x86_64
See also
https://github.com/theforeman/foreman-one/issues/4
https://github.com/fog/fog/pull/3038
0xE2356889.asc (3.06 KB)
Arnold Bechtoldt
Karlsruhe, Germany
can help…
- Procedure “edit Compute Profile” => undefined method
`vm_description’…(see below)
Successfullydecrypted field forForemanOne::OneOpenNebula
OperationFAILED:undefinedmethod `vm_description’ for
#Fog::Compute::OpenNebula::Server:0x007f9ed81d4f38
ActiveRecord: 10.4ms)
NoMethodError
undefinedmethod vm_description' for #<Fog::Compute::OpenNebula::Server:0x007f9ed81d4f38> app/models/compute_attribute.rb:26:in
pretty_vm_attrs’
create’
call’
*- Procedure “create new host” => |operatordoes notexist…(see below)||
Unableto save
Queryinstance details fortesthost.cesystems.at task failed withthe
following error:PGError:ERROR:operatordoes notexist:character varying
=integer LINE 1:…D “hosts”."location_id"IN (3)AND
“hosts”.“uuid”=11LIMIT…^HINT:Nooperatormatches the given name
andargument type(s).Youmight need to add explicittype casts.:SELECT
“hosts”.*FROM "hosts"WHERE “hosts”."organization_id"IN (4)AND
“hosts”."location_id"IN (3)AND “hosts”.“uuid”=11LIMIT 1
Package List:
ForemanServer
OpenNebulaServer:
Groups “Foreman users” group.
an email to foreman-users+unsubscribe@googlegroups.com
