I'm trying to get a handle on how to provision standard cloud images on
OpenStack using Foreman. I keep getting VM's I cannot access because
Foreman has configured the instance with it's own SSH key, making it
impossible for me to ssh in using my own key. How can I specify additional
SSH key(s) to use (preferably a keypair that's already registered in
OpenStack)?
Surely there must be something I'm missing?
Bryce
> OpenStack)?
You can use cloud-init to set some additional keys. An example I wrote
for Red Hat-based OS's. I need to come back and make this more
generic eventually…
https://github.com/stbenjam/community-templates/blob/userdata-cc/kickstart/userdata.erb
Anyway, you can do something like this in the cloud init:
ssh_authorized_keys:
- <%= @host.params['sshkey'] %>
And then use a Foreman parameter to set the SSH key.
On Wed, Feb 11, 2015 at 06:03:47PM -0700, Bryce L Nordgren wrote:
Surely there must be something I’m missing?
Bryce
Thanks much! Your example is exactly what I needed, and I can now get into
my Fedora 21 box. Now I'm off to try and figure out how to set up an
iPython notebook server using puppet classes + foreman.
I’m trying to get a handle on how to provision standard cloud images on
OpenStack using Foreman. I keep getting VM’s I cannot access because
Foreman has configured the instance with it’s own SSH key, making it
additional
SSH key(s) to use (preferably a keypair that’s already registered in
OpenStack)?
for Red Hat-based OS’s. I need to come back and make this more
generic eventually…
- <%= @host.params[‘sshkey’] %>
Bryce
"Foreman users" group.
