I have Foreman 1.11.4 (actually Katello 3.0) and I'm trying to setup a
compute resource on ovirt 4.0. When I trigger Load Datacenters on the
initial configuration page I get "Unable to save undefined method `+' for
nil:NilClass".
Is ovirt 4 supported? Can anyone give me any pointers? Hitting the API with
curl seems to work fine - I can list the DCs.
Alan
It isn't, it's tracked under ticket
Bug #15560: Use APIv3 with oVirt 4 - Foreman.
On 26/07/16 11:21, apgriffiths79@gmail.com wrote:
> Hi,
> for nil:NilClass".
Dominic Cleal
dominic@cleal.org
Thanks. Forcing API to v3 as per the ticket seems to have done the trick.
On Tuesday, 26 July 2016 11:55:10 UTC+1, Dominic Cleal wrote:
> On 26/07/16 11:21, apgrif...@gmail.com wrote:
> > Hi,
> > for nil:NilClass".
> http://projects.theforeman.org/issues/15560.
> Dominic Cleal
> dom...@cleal.org
