Correct me if I am wrong but I am under impression that I should be able to
deploy new ovirt template based VM's and that newly created VM should use
template's disk as well, similar to template based VM creation in ovirt. Is
that correct?
If so I am hitting a problem with my foreman where VM is created but the
template disk is not cloned for some reason. I am quite new to foreman so
apologies if I am missing something.
> Hi All,
> Correct me if I am wrong but I am under impression that I should be able to deploy new ovirt template based VM's and that newly created VM should use template's disk as well, similar to template based VM
> creation in ovirt. Is that correct?
> If so I am hitting a problem with my foreman where VM is created but the template disk is not cloned for some reason. I am quite new to foreman so apologies if I am missing something.
> I can see similar issue reported over 3 (!) years ago and left without any update - Bug #3750: Cloning oVirt VMs doesn't create a new disk - Foreman ;/
> I am running
> ovrit 4.1.4.2
> foreman (1.15.0,1,2,3)
> Any ideas how to fix this?
> Regards,
> Tomasz
> To unsubscribe from this group and stop receiving emails from it, send an email to foreman-users+unsubscribe@googlegroups.com.
Initial ovirt template has been created using Thin Provision allocation…
Tomasz
On Thursday, 24 August 2017 09:50:04 UTC+1, Ivan Necas wrote:
> Tomasz Zajączkowski <tozajac...@gmail.com > writes:
> > Hi All,
> any update - http://projects.theforeman.org/issues/3750 ;/
> > I am running
> > ovrit 4.1.4.2
> Hi,
> Are you using 'preallocate disk' flag on the template? We have currently
> https://github.com/theforeman/foreman/pull/4512 opened, that should
> address the issue in this case. Note it needs newer fog: the dependency
> bump is in other PR (waiting for merge
> https://github.com/theforeman/foreman/pull/4672)
> -- Ivan
> > Regards,
> > Tomasz
> an email to foreman-user...@googlegroups.com .
> > To post to this group, send email to forema...@googlegroups.com
