Passenger error after system reboot
Hey folks, I get foreman/katello up and running with the installer but
after i reboot the system passenger doesn't start and I get the following
error…
*** ERROR: The Nginx binary
'/usr/share/gems/gems/passenger-4.0.18/lib/nginx'
does not exist.
I can find no errors in the installation or in the foreman log. I get a
403 error from apache and that's all. I'm sure this has been answered
already but I haven't been able to find the thread… Thanks
Hey,
there was a bug caused by files disappearing after restart, but I doubt
it is related. To be fixed in the next RC.
> error…
> does not exist.
Platform? Version of Foreman/Katello?
This looks like the system passenger gem which is used only for Puppet
Master…
I'm using centos 7 Katello 2.2 and foreman 1.8RC. What's strange is there
seems to be no errors in the logs.
··· On Thursday, April 9, 2015 at 7:36:58 AM UTC-4, Lukas Zapletal wrote: > > Hey, > > there was a bug caused by files disappearing after restart, but I doubt > it is related. To be fixed in the next RC. > > > Hey folks, I get foreman/katello up and running with the installer but > > after i reboot the system passenger doesn't start and I get the > following > > error.. > > > > *** ERROR: The Nginx binary > > '/usr/share/gems/gems/passenger-4.0.18/lib/nginx' > > does not exist. > > I can find no errors in the installation or in the foreman log. I get > a > > 403 error from apache and that's all. I'm sure this has been answered > > already but I haven't been able to find the thread.. Thanks > > Platform? Version of Foreman/Katello? > > This looks like the system passenger gem which is used only for Puppet > Master... > > -- > Later, > Lukas #lzap Zapletal >
Brandon Merjil found the cause, which was the wrong directory specified
in /usr/lib/tmpfiles.d/rubygem-passenger.conf, which should have been
/var/run/rubygem-passenger and not just "passenger".
See his post here:
https://groups.google.com/d/msg/foreman-users/3MHR63htdEQ/lvynamK3_VoJ
You can just edit this config file and fix the directory. We have
updated packages built for 1.8.0-RC3 which I think will be out at the
start of next week.
··· -- Dominic Cleal Red Hat Engineering
On 10/04/15 00:05, Ryan Jones wrote:
I’m using centos 7 Katello 2.2 and foreman 1.8RC. What’s strange is
there seems to be no errors in the logs.
Hey,
but
following
> error..
> does not exist.
 I get a
Master...
Later,
Groups “Foreman users” group.
an email to foreman-users+unsubscribe@googlegroups.com
Thanks that did the trick
··· On Friday, April 10, 2015 at 3:31:33 AM UTC-4, Dominic Cleal wrote: > > Brandon Merjil found the cause, which was the wrong directory specified > in /usr/lib/tmpfiles.d/rubygem-passenger.conf, which should have been > /var/run/rubygem-passenger and not just "passenger". > > See his post here: > https://groups.google.com/d/msg/foreman-users/3MHR63htdEQ/lvynamK3_VoJ > > You can just edit this config file and fix the directory. We have > updated packages built for 1.8.0-RC3 which I think will be out at the > start of next week. > > -- > Dominic Cleal > Red Hat Engineering > > On 10/04/15 00:05, Ryan Jones wrote: > > I'm using centos 7 Katello 2.2 and foreman 1.8RC. What's strange is > > there seems to be no errors in the logs. > > > > On Thursday, April 9, 2015 at 7:36:58 AM UTC-4, Lukas Zapletal wrote: > > > > Hey, > > > > there was a bug caused by files disappearing after restart, but I > doubt > > it is related. To be fixed in the next RC. > > > > > Hey folks, I get foreman/katello up and running with the installer > > but > > > after i reboot the system passenger doesn't start and I get the > > following > > > error.. > > > > > > *** ERROR: The Nginx binary > > > '/usr/share/gems/gems/passenger-4.0.18/lib/nginx' > > > does not exist. > > > I can find no errors in the installation or in the foreman log. > > I get a > > > 403 error from apache and that's all. I'm sure this has been > answered > > > already but I haven't been able to find the thread.. Thanks > > > > Platform? Version of Foreman/Katello? > > > > This looks like the system passenger gem which is used only for > Puppet > > Master... > > > > -- > > Later, > > Lukas #lzap Zapletal > > > > -- > > You received this message because you are subscribed to the Google > > Groups "Foreman users" group. > > To unsubscribe from this group and stop receiving emails from it, send > > an email to foreman-user...@googlegroups.com > > <mailto:foreman-users+unsubscribe@googlegroups.com >. > > To post to this group, send email to forema...@googlegroups.com > > > <mailto:forema...@googlegroups.com >. > > Visit this group at http://groups.google.com/group/foreman-users. > > For more options, visit https://groups.google.com/d/optout. > > >
