Hi
I run into a problem:
http://projects.theforeman.org/issues/17703
So i did as it was suggested:
":run_always => true" seems to be a remnant of the previous 30-upgrade.rb
where every upgrade_step had a ":run_always" or ":long_running" option
passed. With the 3.2.1 30-upgrade.rb ":migrate_candlepin" is the only
upgrade_step with an option and since the function only takes one argument
this results in the error seen.
Deleting ", :run_always => true" lets the upgrade continue.
But after that I have an error:
Upgrade Step: db_seed…
rake aborted!
RestClient::ResourceNotFound: 404 Resource Not Found
/opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-1.8.0/lib/restclient/abstract_response.rb:74:in
return!' /opt/theforeman/tfm/root/usr/share/gems/gems/runcible-1.9.0/lib/runcible/base.rb:79:in
block in get_response'
/opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-1.8.0/lib/restclient/request.rb:493:in
call' /opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-1.8.0/lib/restclient/request.rb:493:in
process_result'
/opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-1.8.0/lib/restclient/request.rb:421:in
block in transmit' /opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-1.8.0/lib/restclient/request.rb:413:in
transmit'
/opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-1.8.0/lib/restclient/request.rb:176:in
execute' /opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-1.8.0/lib/restclient/request.rb:41:in
execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-1.8.0/lib/restclient/resource.rb:51:in
get' /opt/theforeman/tfm/root/usr/share/gems/gems/runcible-1.9.0/lib/runcible/base.rb:78:in
get_response'
/opt/theforeman/tfm/root/usr/share/gems/gems/runcible-1.9.0/lib/runcible/base.rb:66:in
call' /opt/theforeman/tfm/root/usr/share/gems/gems/runcible-1.9.0/lib/runcible/resources/event_notifier.rb:48:in
list'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.2.1.1/app/models/katello/glue/pulp/repo.rb:32:in
ensure_sync_notification' /opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.2.1.1/db/seeds.d/108-ensure_sync_notification.rb:9:in
<top (required)>'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/dependencies.rb:268:in
load' /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/dependencies.rb:268:in
block in load'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/dependencies.rb:240:in
load_dependency' /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/dependencies.rb:268:in
load'
/usr/share/foreman/db/seeds.rb:81:in block in <top (required)>' /usr/share/foreman/db/seeds.rb:79:in
each'
/usr/share/foreman/db/seeds.rb:79:in <top (required)>' /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/dependencies.rb:268:in
load'
block in load' /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/dependencies.rb:240:in
load_dependency'
load' /opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/engine.rb:547:in
load_seed'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/tasks/database_tasks.rb:250:in
load_seed' /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/railties/databases.rake:183:in
block (2 levels) in <top (required)>'
Tasks: TOP => db:seed
Seeding /usr/share/foreman/db/seeds.d/03-auth_sources.rb
Seeding /usr/share/foreman/db/seeds.d/03-permissions.rb
Seeding /usr/share/foreman/db/seeds.d/03-roles.rb
Seeding /usr/share/foreman/db/seeds.d/04-admin.rb
Seeding /usr/share/foreman/db/seeds.d/05-taxonomies.rb
Seeding /usr/share/foreman/db/seeds.d/06-architectures.rb
Seeding /usr/share/foreman/db/seeds.d/07-provisioning_templates.rb
Seeding /usr/share/foreman/db/seeds.d/08-partition_tables.rb
Seeding /usr/share/foreman/db/seeds.d/10-installation_media.rb
Seeding
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.2.1.1/db/seeds.d/101-locations.rb
Seeding
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.2.1.1/db/seeds.d/102-organizations.rb
Seeding
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.2.1.1/db/seeds.d/103-provisioning_templates.rb
Seeding
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.2.1.1/db/seeds.d/104-proxy.rb
Seeding
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.2.1.1/db/seeds.d/106-mail_notifications.rb
Seeding
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.2.1.1/db/seeds.d/107-enable_dynflow.rb
Seeding
Upgrade step db_seed failed. Check logs for more information.
Can anypne please help.?
