Hi all,
I am trying to publish a new version of a content view that has RHEL
content, but it is stuck at 84% with the error "PLP0000: Pulp exception
occurred: PulpExecutionException"
If I go to the dynaflow console, it is stuck at "966:
Actions::Pulp::Repository::CopyYumMetadataFile (error)"
Started at: 2016-08-17 21:11:17 UTC
Ended at: 2016-08-17 21:11:18 UTC
Real time: 1.30s
Execution time (excluding suspended state): 0.65s
Input:
--- source_pulp_id: NIWA-Red_Hat_Enterprise_Linux_Server-Red_Hat_Enterprise_Linux_7_Server_-_Supplementary_RPMs_x86_64_7Server target_pulp_id: NIWA-RHEL7_Server-37_0-Red_Hat_Enterprise_Linux_Server-Red_Hat_Enterprise_Linux_7_Server_-_Supplementary_RPMs_x86_64_7Server clauses: remote_user: admin remote_cp_user: adminOutput:
pulp_tasks:- exception:
task_type: pulp.server.managers.repo.unit_association.associate_from_repo
_href: "/pulp/api/v2/tasks/05d9f48e-dcc6-4ddd-8cd8-28efb7ab676a/"
task_id: 05d9f48e-dcc6-4ddd-8cd8-28efb7ab676a
tags:
- pulp:repository:NIWA-RHEL7_Server-37_0-Red_Hat_Enterprise_Linux_Server-Red_Hat_Enterprise_Linux_7_Server_-_Supplementary_RPMs_x86_64_7Server
- pulp:repository:NIWA-Red_Hat_Enterprise_Linux_Server-Red_Hat_Enterprise_Linux_7_Server_-_Supplementary_RPMs_x86_64_7Server
- pulp:action:associate
finish_time: ‘2016-08-17T21:11:18Z’
_ns: task_status
start_time: '2016-08-17T21:11:18Z’
traceback: |
File “/usr/lib/python2.7/site-packages/celery/app/trace.py”, line 240, in trace_task
R = retval = fun(*args, **kwargs)
File “/usr/lib/python2.7/site-packages/pulp/server/async/tasks.py”, line 473, in call
return super(Task, self).call(*args, **kwargs)
File “/usr/lib/python2.7/site-packages/pulp/server/async/tasks.py”, line 103, in call
return super(PulpTask, self).call(*args, **kwargs)
File “/usr/lib/python2.7/site-packages/celery/app/trace.py”, line 437, in protected_call
return self.run(*args, **kwargs)
File “/usr/lib/python2.7/site-packages/pulp/server/managers/repo/unit_association.py”, line 273, in associate_from_repo
units=transfer_units)
File “/usr/lib/python2.7/site-packages/pulp_rpm/plugins/importers/yum/importer.py”, line 57, in import_units
return associate.associate(source_repo, dest_repo, import_conduit, config, units)
File “/usr/lib/python2.7/site-packages/pulp_rpm/plugins/importers/yum/associate.py”, line 53, in associate
associated_units = set([_associate_unit(dest_repo, unit) for unit in units])
File “/usr/lib/python2.7/site-packages/pulp_rpm/plugins/importers/yum/associate.py”, line 333, in _associate_unit
return associate_copy_for_repo(unit, dest_repo, True)
File “/usr/lib/python2.7/site-packages/pulp_rpm/plugins/importers/yum/associate.py”, line 369, in associate_copy_for_repo
new_unit.safe_import_content(unit._storage_path)
File “/usr/lib/python2.7/site-packages/pulp/server/db/model/init.py”, line 905, in safe_import_content
self.import_content(path, location)
File “/usr/lib/python2.7/site-packages/pulp/server/db/model/init.py”, line 877, in import_content
raise exceptions.PulpCodedException(error_code=error_codes.PLP0037, path=path)
PulpExecutionException: Pulp exception occurred: PulpExecutionException
spawned_tasks: []
progress_report: {}
queue: reserved_resource_worker-4@wellkatello.dq
state: error
worker_name: reserved_resource_worker-4@wellkatello
error:
code: PLP0000
data: {}
description: 'Pulp exception occurred: PulpExecutionException’
sub_errors: []
_id:
"$oid": 57b4d2f513f5c6fec4e80642
poll_attempts:
total: 1
failed: 1
Error:
Katello::Errors::PulpError
PLP0000: Pulp exception occurred: PulpExecutionException
---- “/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.0.2/app/lib/actions/pulp/abstract_async_task.rb:121:in
block in external_task='"- "/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.0.2/app/lib/actions/pulp/abstract_async_task.rb:119:in
each’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.0.2/app/lib/actions/pulp/abstract_async_task.rb:119:in
external_task='"- "/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.0.2/app/lib/actions/pulp/repository/abstract_copy_content.rb:40:in
external_task=’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.11/lib/dynflow/action/polling.rb:98:in
poll_external_task_with_rescue'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.11/lib/dynflow/action/polling.rb:21:in
run’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.11/lib/dynflow/action/cancellable.rb:9:in
run'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.0.2/app/lib/actions/pulp/abstract_async_task.rb:45:in
run’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.11/lib/dynflow/action.rb:506:in
block (3 levels) in execute_run'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.11/lib/dynflow/middleware/stack.rb:26:in
call’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.11/lib/dynflow/middleware/stack.rb:26:in
pass'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.11/lib/dynflow/middleware.rb:17:in
pass’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.11/lib/dynflow/middleware.rb:30:in
run'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.11/lib/dynflow/middleware/stack.rb:22:in
pass’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.0.2/app/lib/actions/middleware/remote_action.rb:16:in
block in run'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.0.2/app/lib/actions/middleware/remote_action.rb:40:in
block in as_remote_user’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.0.2/app/models/katello/concerns/user_extensions.rb:20:in
cp_config'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.0.2/app/lib/actions/middleware/remote_action.rb:27:in
as_cp_user’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.0.2/app/lib/actions/middleware/remote_action.rb:39:in
as_remote_user'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.0.2/app/lib/actions/middleware/remote_action.rb:16:in
run’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.11/lib/dynflow/middleware/stack.rb:22:in
call'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.11/lib/dynflow/middleware/stack.rb:26:in
pass’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.11/lib/dynflow/middleware.rb:17:in
pass'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.11/lib/dynflow/action/progress.rb:30:in
with_progress_calculation’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.11/lib/dynflow/action/progress.rb:16:in
pass’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.0.2/app/lib/actions/middleware/keep_locale.rb:11:in
block in run'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.0.2/app/lib/actions/middleware/keep_locale.rb:22:in
with_locale’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.0.2/app/lib/actions/middleware/keep_locale.rb:11:in
call’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.11/lib/dynflow/middleware/world.rb:30:in
execute'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.11/lib/dynflow/action.rb:505:in
block (2 levels) in execute_run’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.11/lib/dynflow/action.rb:504:in
catch'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.11/lib/dynflow/action.rb:504:in
block in execute_run’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.11/lib/dynflow/action.rb:419:in
call'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.11/lib/dynflow/action.rb:419:in
block in with_error_handling’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.11/lib/dynflow/action.rb:419:in
catch'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.11/lib/dynflow/action.rb:419:in
with_error_handling’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.11/lib/dynflow/action.rb:499:in
execute_run'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.11/lib/dynflow/action.rb:260:in
execute’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.11/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:9:in
block (2 levels) in execute'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.11/lib/dynflow/execution_plan/steps/abstract.rb:155:in
call’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.11/lib/dynflow/execution_plan/steps/abstract.rb:155:in
with_meta_calculation'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.11/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:8:in
block in execute’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.11/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:22:in
open_action'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.11/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:7:in
execute’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.11/lib/dynflow/executors/parallel/worker.rb:15:in
block in on_message'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/algebrick-0.7.3/lib/algebrick/matchers/abstract.rb:74:in
block in assigns’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/algebrick-0.7.3/lib/algebrick/matchers/abstract.rb:73:in
tap'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/algebrick-0.7.3/lib/algebrick/matchers/abstract.rb:73:in
assigns’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/algebrick-0.7.3/lib/algebrick/matching.rb:56:in
match_value'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/algebrick-0.7.3/lib/algebrick/matching.rb:36:in
block in match?’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/algebrick-0.7.3/lib/algebrick/matching.rb:35:in
each'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/algebrick-0.7.3/lib/algebrick/matching.rb:35:in
match?’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/algebrick-0.7.3/lib/algebrick/matching.rb:23:in
match'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.11/lib/dynflow/executors/parallel/worker.rb:12:in
on_message’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.0/lib/concurrent/actor/context.rb:46:in
on_envelope'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.0/lib/concurrent/actor/behaviour/executes_context.rb:7:in
on_envelope’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.0/lib/concurrent/actor/behaviour/abstract.rb:25:in
pass'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-0.8.11/lib/dynflow/actor.rb:26:in
pass'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.0/lib/concurrent/actor/behaviour/awaits.rb:15:in
pass'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.0/lib/concurrent/actor/behaviour/sets_results.rb:14:in
pass'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.0/lib/concurrent/actor/behaviour/buffer.rb:38:in
process_envelope’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.0/lib/concurrent/actor/behaviour/buffer.rb:31:in
process_envelopes?'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.0/lib/concurrent/actor/behaviour/buffer.rb:20:in
pass'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.0/lib/concurrent/actor/behaviour/termination.rb:55:in
pass'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.0/lib/concurrent/actor/behaviour/removes_child.rb:10:in
on_envelope’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.0/lib/concurrent/actor/core.rb:161:in
process_envelope'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.0/lib/concurrent/actor/core.rb:95:in
block in on_envelope’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.0/lib/concurrent/actor/core.rb:118:in
block (2 levels) in schedule_execution'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.0/lib/concurrent/synchronization/mri_lockable_object.rb:38:in
block in synchronize’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.0/lib/concurrent/synchronization/mri_lockable_object.rb:38:in
synchronize'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.0/lib/concurrent/synchronization/mri_lockable_object.rb:38:in
synchronize’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-edge-0.2.0/lib/concurrent/actor/core.rb:115:in
block in schedule_execution'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.0/lib/concurrent/executor/serialized_execution.rb:18:in
call’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.0/lib/concurrent/executor/serialized_execution.rb:18:in
call'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.0/lib/concurrent/executor/serialized_execution.rb:96:in
work’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.0/lib/concurrent/executor/serialized_execution.rb:77:in
block in call_job'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.0/lib/concurrent/executor/ruby_thread_pool_executor.rb:333:in
call’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.0/lib/concurrent/executor/ruby_thread_pool_executor.rb:333:in
run_task'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.0/lib/concurrent/executor/ruby_thread_pool_executor.rb:322:in
block (3 levels) in create_worker’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.0/lib/concurrent/executor/ruby_thread_pool_executor.rb:305:in
loop'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.0/lib/concurrent/executor/ruby_thread_pool_executor.rb:305:in
block (2 levels) in create_worker’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.0/lib/concurrent/executor/ruby_thread_pool_executor.rb:304:in
catch'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/concurrent-ruby-1.0.0/lib/concurrent/executor/ruby_thread_pool_executor.rb:304:in
block in create_worker’”- “/opt/theforeman/tfm/root/usr/share/gems/gems/logging-1.8.2/lib/logging/diagnostic_context.rb:323:in
call'"- "/opt/theforeman/tfm/root/usr/share/gems/gems/logging-1.8.2/lib/logging/diagnostic_context.rb:323:in
block in create_with_logging_context’”
If I resume the job while monitoring /var/log/messages for pulp messages, I
was seeing
Aug 17 16:19:36 wellkatello.niwa.local pulp: celery.worker.strategy:INFO:
Received task:
pulp.server.async.tasks._release_resource[0c85402f-a9ca-4571-a1c7-7f2371282f3b]
Aug 17 16:19:36 wellkatello.niwa.local pulp: celery.worker.job:INFO: Task
pulp.server.async.tasks._queue_reserved_task[e1bebe64-7f44-417b-8ca7-564e9e6b0538]
succeeded in 0.303873108s: None
pulp.server.managers.repo.unit_association:ERROR: (4695-73376) Exception
from importer [yum_importer] while importing units into repository
[NIWA-RHEL7_Server-36_0-Oracle_Java__for_RHEL_Serve$
pulp.server.managers.repo.unit_association:ERROR: (4695-73376) Traceback
pulp.server.managers.repo.unit_association:ERROR: (4695-73376) File
"/usr/lib/python2.7/site-packages/pulp/server/managers/repo/unit_association.py",
"/usr/lib/python2.7/site-packages/pulp_rpm/plugins/importers/yum/importer.py",
pulp.server.managers.repo.unit_association:ERROR: (4695-73376) return
"/usr/lib/python2.7/site-packages/pulp_rpm/plugins/importers/yum/associate.py",
"/usr/lib/python2.7/site-packages/pulp/server/db/model/init.py", line
