OS: CentOS 7.8
Foreman: 1.24.2
Katello: 3.14.1
I attempted to backup my system with foreman-maintain. The command I used was this:
foreman-maintain backup offline --whitelist=“sync-plans-disable” --skip-pulp-content -y /var/backup
It produced this output:
[root@fm ~]# foreman-maintain backup offline --whitelist=“sync-plans-disable” --skip-pulp-content -y /var/backup
Starting backup: 2021-02-02 11:09:15 -0500
Running preparation steps required to run the next scenariosMake sure Foreman DB is up:
/ Checking connection to the Foreman DB [OK]Running Backup
Confirm turning off services is allowed:
WARNING: This script will stop your services.[OK]
Prepare backup Directory:
Creating backup folder /var/backup/katello-backup-2021-02-02-11-09-15 [OK]Check if the directory exists and is writable: [OK]
Generate metadata:
\ Saving metadata to metadata.yml [OK]Detect features available in the local proxy: [OK]
disable active sync plans: [SKIPPED]
Add maintenance_mode chain to iptables: [OK]
Stop applicable services:
Stopping the following service(s):rh-mongodb34-mongod, postgresql, qdrouterd, qpidd, squid, pulp_celerybeat, pulp_resource_manager, pulp_streamer, pulp_workers, smart_proxy_dynflow_core, tomcat, dynflowd, goferd, httpd, pup
petserver, foreman-proxy
\ All services stopped [OK]Backup config files:
\ Collecting config files to backup [OK]Backup Pulp data: [SKIPPED]
Backup mongo offline:
- Collecting Mongo data [OK]
Backup Candlepin DB offline:
/ Collecting data from /var/lib/pgsql/data/ [OK]Backup Foreman DB offline:
Already done [OK]Start applicable services:
Starting the following service(s):rh-mongodb34-mongod, postgresql, qdrouterd, qpidd, squid, pulp_celerybeat, pulp_resource_manager, pulp_streamer, pulp_workers, smart_proxy_dynflow_core, tomcat, dynflowd, goferd, httpd, puppetserver, foreman-proxy
| starting puppetserver
Job for puppetserver.service failed because the control process exited with error code. See “systemctl status puppetserver.service” and “journalctl -xe” for details.
\ All services started [OK]re-enable sync plans:
/ re-enabling sync plans [FAIL]
Could not update the sync plan:
Couldn’t find sync plan ‘4’ in organization ‘’Scenario [Backup] failed.
[sync-plans-enable]
Resolve the failed steps and rerun
the command. In case the failures are false positives,
use --whitelist=“sync-plans-enable”Running Failed backup cleanup
- starting puppetserver
\ re-enabling sync plans [FAIL]
Couldn’t find sync plan ‘4’ in organization ‘’Remove maintenance_mode chain from iptables: [OK]
Clean up backup directory: [OK]
Scenario [Failed backup cleanup] failed.
[sync-plans-enable]
use --whitelist=“sync-plans-enable”Done with backup: 2021-02-02 11:25:12 -0500
Backup didn’t finish. Incomplete backup was removed.
It was doing great until it got to the point of re-enabling the syncplans. Then it cleared out the data it backed up and failed.
I looked at the file /var/lib/foreman-maintain/data.yml and noticed that it had 3 sync plans listed by number that were long since deleted from the system so I removed them from that file and re-ran the backup. It still failed at the same point. This time it just said:
Couldn’t find sync plan ‘’ in organization ‘’
I looked up the error and some one suggested removing the data.yml file and then running foreman-maintain upgrade check --target-version= but I do not know what version to look for. So I tried foreman-maintain upgrade list-versions and it was unable to list any versions.
Anyone have any suggestions?
