As mentioned in the subject, I have a problem during provisioning at the host registering phase.
In the post-installation script’s log I can see following output:
Registering the System
+ subscription-manager register --org=Production --name=server.example.com --activationkey=Katello_activation_key
Task 38aeae2b-80b1-49e1-a94d-9993587a5fdc: ActiveRecord::RecordInvalid: Validation failed: Host has already been taken
Usually, this should looks like the following:
+ subscription-manager register --org=Production --name=server2.example.com --activationkey=Katello_activation_key
The system has been registered with ID: 41260a81-9a39-4562-b022-565c6163bb7a
In the logs I could find something similar to:
2018-02-16 13:27:53 [katello/cp_rest] [D] Resource GET request: /candlepin/activation_keys/?include=id&include=pools.pool.id
2018-02-16 13:27:53 [katello/cp_rest] [D] Headers: {"accept":"application/json","accept-language":"en","content-type":"application/json","cp-user":"foreman_admin"}
2018-02-16 13:27:53 [katello/cp_rest] [D] Body: {}
2018-02-16 13:27:53 [app] [D] Setting current user thread-local variable to nil
2018-02-16 13:27:53 [foreman-tasks/action] [E] Validation failed: Host has already been taken (ActiveRecord::RecordInvalid)
| /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/validations.rb:79:in `raise_record_invalid'
| /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/validations.rb:43:in `save!'
and
2018-02-16 13:27:53 12bad314 [katello/cp_proxy] [E] ForemanTasks::TaskError: Task 38aeae2b-80b1-49e1-a94d-9993587a5fdc: ActiveRecord::RecordInvalid: Validation failed: Host has already been taken
| /opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.9.6/lib/foreman_tasks.rb:40:in `block in sync_task'
| /opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.9.6/lib/foreman_tasks.rb:39:in `tap'
| /opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.9.6/lib/foreman_tasks.rb:39:in `sync_task'
| /opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.9.6/lib/foreman_tasks/triggers.rb:22:in `sync_task'
Interesting thing is, that it is not happening every time. This happens once in 3/4 provisioning attempts…
foreman-proxy-1.15.6-1.el7.noarch
foreman-release-1.15.6-1.el7.noarch
katello-3.4.5-1.el7.noarch
katello-agent-3.0.2-1.el7.noarch
If there is a need for any other symptoms, just let me know.
I will be glad if anyone of you could help me with this.
Thanks and regards!!
