syncronization failing when random 502 errors occur
would like to either retry 502 failures or syncronize the repo in smaller chunks
foreman-selinux-1.23.0-1.el7.noarch
foreman-cli-1.23.0-1.el7.noarch
foreman-installer-katello-1.23.0-1.el7.noarch
foreman-proxy-1.23.0-1.el7.noarch
foreman-1.23.0-1.el7.noarch
foreman-postgresql-1.23.0-1.el7.noarch
foreman-installer-1.23.0-1.el7.noarch
foreman-debug-1.23.0-1.el7.noarch
foreman-vmware-1.23.0-1.el7.noarch
python-nectar-1.6.0-1.el7.noarch
pulp-selinux-2.19.1-1.el7.noarch
pulp-puppet-plugins-2.19.1-1.el7.noarch
pulp-docker-plugins-3.2.4-1.el7.noarch
pulp-deb-plugins-1.9.1-1.el7.noarch
pulp-server-2.19.1-1.el7.noarch
pulp-puppet-tools-2.19.1-1.el7.noarch
pulp-client-1.0-1.noarch
pulp-rpm-plugins-2.19.1-1.el7.noarch
pulp-katello-1.0.3-1.el7.noarch
Initial sync of Ubuntu Universe failing. sync is happening through a proxy we have no control over and we occasionally get “failed with code 502: cannotconnect” which is enough to fail the entire initial sync.
Nov 13 00:16:51 foreman.internal pulp: nectar.downloaders.threaded:INFO: Download succeeded: http://ca.archive.ubuntu.com/ubuntu/pool/universe/g/gcc-7-cross/lib32stdc++-7-dev-s390x-cross_7.3.0-16ubuntu3cross1_all.deb.
Nov 13 16:29:52 foreman.internal pulp: nectar.downloaders.threaded:INFO: Download failed: Download of http://ca.archive.ubuntu.com/ubuntu/pool/universe/g/gcc-7-cross/lib32stdc++-7-dev-s390x-cross_7.3.0-16ubuntu3cross1_all.deb failed with code 502: cannotconnect
Nov 13 16:35:04 foreman.internal pulp: celery.app.trace:ERROR: [f0cd450f] (9977-61920) IOError: [Errno 2] No such file or directory: u'/var/cache/pulp/reserved_resource_worker-0@foreman.internal/f0cd450f-c057-475c-aa32-d8cb99459c53/packages/6b/7c/lib32stdc++-7-dev-s390x-cross_7.3.0-16ubuntu3cross1_all.deb'
