When I try to instantiate an host to oVirt with Foreman API I pass the
correct compute_resource_id and details for network and volumes variables.
But when I try to POST it Foreman give me this error:
"Unable to save": "Failed to create a compute xxx (oVirt) instance
host_prova.xxx: User is not authorized to perform this action…".
But the user in oVirt creates the host normally, so I tried to create the
host with Foreman GUI but I obtain the same error.
Do you know How can I solve this problem?
Thanks in advance for your support
In addition to what I said inform you that POST method return me 422 http
status.
> host_prova.xxx: User is not authorized to perform this action...".
> status.
which foreman version? did you use /api/hosts or /hosts?
Ohad
"Foreman users" group.
Visit this group at http://groups.google.com/group/foreman-users?hl=en.
Thanks for you response. I use http://foreman.xxx/hosts. Now I don't see
Foreman versione for some problem in the infrastructure area but I think it
is 1.0.1.
Il giorno giovedì 23 maggio 2013 15:53:36 UTC+2, ohad ha scritto:
>> http status.
>>> the host with Foreman GUI but I obtain the same error.
> Ohad
Please. Do you know why I have this problem
> is 1.0.1.
>>> http status.
>> Ohad
>>> Groups "Foreman users" group.
>>> an email to foreman-user...@googlegroups.com.
>>> To post to this group, send email to forema...@googlegroups.com.
I warn you that I solved my problem. Anyway I have an important question
for you. If my user has admin credential in ovirt it can create an host
with simplicity, but if I use an user with less privileges it has some
problems to instantiate an host with Foreman on Ovirt in spite this user
can create a vm in Ovirt without problems. I have noticed that in Ovirt api
to create an host with this kind of user, we need to set an important flag
on true. So my question is: do Foreman use this flag or not? If it is,
Foreman can instantiate vm with Ovirt only with admin credential in Ovirt.
>> http status.
> Ohad
