I have a huge problem with katello. I had a mismatch between really
available RHEL licences and what was displayed on the interface (on one web
page I had 44 licences available, on an other, it said 0). So talking about
my problem on #katello on IRC, thomasmckay proposed to execute the task
reindex. It didn't worked, then I tried a clean_backend_objects which
didn't worked either until I replaced my local ruby file by the last one
from upstream git.
Then I updated from katello 2.1 to katello 2.2 and tried again a reindex
which still don't work.
Here is the traces of the error
foreman-rake katello:reindex --trace
** Invoke katello:reindex (first_time)
** Execute environment
API controllers newer than Apipie cache! Run apipie:cache rake task to
regenerate cache.
** Invoke katello:reset_backends:elasticsearch (first_time)
** Execute katello:reset_backends:elasticsearch
Elasticsearch Indices cleared.
** Execute katello:reindex
Re-indexing Katello::HostCollection
Re-indexing Katello::System
Re-indexing Katello::Product
Re-indexing Katello::Repository
rake aborted!
undefined method merge' for nil:NilClass /opt/rh/ruby193/root/usr/share/gems/gems/katello-2.2.0/app/models/katello/glue/pulp/repo.rb:91:in
to_hash'
/opt/rh/ruby193/root/usr/share/gems/gems/tire-0.6.2/lib/tire/index.rb:195:in
block in bulk' /opt/rh/ruby193/root/usr/share/gems/gems/tire-0.6.2/lib/tire/index.rb:176:in
map'
bulk' /opt/rh/ruby193/root/usr/share/gems/gems/tire-0.6.2/lib/tire/index.rb:273:in
bulk_store'
/opt/rh/ruby193/root/usr/share/gems/gems/tire-0.6.2/lib/tire/index.rb:300:in
import' /opt/rh/ruby193/root/usr/share/gems/gems/katello-2.2.0/lib/katello/tasks/reindex.rake:19:in
block (3 levels) in <top (required)>'
/opt/rh/ruby193/root/usr/share/gems/gems/katello-2.2.0/lib/katello/tasks/reindex.rake:7:in
each' /opt/rh/ruby193/root/usr/share/gems/gems/katello-2.2.0/lib/katello/tasks/reindex.rake:7:in
block (2 levels) in <top (required)>'
/opt/rh/ruby193/root/usr/share/ruby/rake/task.rb:205:in call' /opt/rh/ruby193/root/usr/share/ruby/rake/task.rb:205:in
block in execute'
/opt/rh/ruby193/root/usr/share/ruby/rake/task.rb:200:in each' /opt/rh/ruby193/root/usr/share/ruby/rake/task.rb:200:in
execute'
/opt/rh/ruby193/root/usr/share/ruby/rake/task.rb:158:in block in invoke_with_call_chain' /opt/rh/ruby193/root/usr/share/ruby/monitor.rb:211:in
mon_synchronize'
/opt/rh/ruby193/root/usr/share/ruby/rake/task.rb:151:in
invoke_with_call_chain' /opt/rh/ruby193/root/usr/share/ruby/rake/task.rb:144:in
invoke'
/opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:116:in invoke_task' /opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:94:in
block (2
levels) in top_level'
/opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:94:in each' /opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:94:in
block in
top_level'
/opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:133:in
standard_exception_handling' /opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:88:in
top_level'
/opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:66:in block in run' /opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:133:in
/opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:63:in run' /opt/rh/ruby193/root/usr/bin/rake:32:in
<main>'
Tasks: TOP => katello:reindex
foreman-rake apipie:cache --trace
** Invoke apipie:cache (first_time)
** Execute apipie:cache
2015-05-27 13:59:01 +0200 | Started
2015-05-27 13:59:13 +0200 | Documents loaded…
2015-05-27 13:59:13 +0200 | Processing docs for
2015-05-27 13:59:50 +0200 | Processing docs for de
2015-05-27 14:00:28 +0200 | Processing docs for es
2015-05-27 14:01:02 +0200 | Processing docs for sv_SE
2015-05-27 14:01:26 +0200 | Processing docs for en
2015-05-27 14:01:41 +0200 | Processing docs for zh_CN
2015-05-27 14:02:07 +0200 | Processing docs for gl
2015-05-27 14:02:31 +0200 | Processing docs for ru
2015-05-27 14:02:56 +0200 | Processing docs for ko
2015-05-27 14:03:20 +0200 | Processing docs for it
2015-05-27 14:03:45 +0200 | Processing docs for fr
2015-05-27 14:04:09 +0200 | Processing docs for ja
2015-05-27 14:04:35 +0200 | Processing docs for zh_TW
2015-05-27 14:05:00 +0200 | Processing docs for pt_BR
2015-05-27 14:05:26 +0200 | Processing docs for en_GB
2015-05-27 14:05:50 +0200 | Finished
rake aborted!
to_hash'
map'
bulk_store'
block in execute'
execute'
mon_synchronize'
invoke'
block (2
block in
top_level'
top_level'
<main>'
Nicolas MICHEL
Collaborating on IRC #katello, we were only partially able to solve this with a rake task[1]. While this task cleaned up the repositories, there are content views that were in an error state during deletion that further blocked progress. The unfortunate result required a reinstall of katello-2.2.
[1] https://access.redhat.com/solutions/1453313
----- Original Message -----
> Hi,
> from upstream git.
> # foreman-rake katello:reindex --trace
> regenerate cache.
> rake aborted!
> undefined method `merge' for nil:NilClass
> `to_hash'
> `block in bulk'
> `map'
> `bulk'
> `bulk_store'
> `import'
> `block (3 levels) in '
> `each'
> `block (2 levels) in '
> /opt/rh/ruby193/root/usr/share/ruby/rake/task.rb:205:in `call'
> /opt/rh/ruby193/root/usr/share/ruby/rake/task.rb:205:in `block in execute'
> /opt/rh/ruby193/root/usr/share/ruby/rake/task.rb:200:in `each'
> /opt/rh/ruby193/root/usr/share/ruby/rake/task.rb:200:in `execute'
> /opt/rh/ruby193/root/usr/share/ruby/rake/task.rb:158:in `block in
> /opt/rh/ruby193/root/usr/share/ruby/monitor.rb:211:in `mon_synchronize'
> `invoke_with_call_chain'
> /opt/rh/ruby193/root/usr/share/ruby/rake/task.rb:144:in `invoke'
> /opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:116:in `invoke_task'
> /opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:94:in `block (2
> /opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:94:in `each'
> /opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:94:in `block in
> top_level'
> `standard_exception_handling'
> /opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:88:in `top_level'
> /opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:66:in `block in run'
> /opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:63:in `run'
> /opt/rh/ruby193/root/usr/bin/rake:32:in `'
> # foreman-rake apipie:cache --trace
> 2015-05-27 13:59:13 +0200 | Documents loaded...
> rake aborted!
> `to_hash'
> `block in bulk'
> `map'
> `bulk'
> `bulk_store'
> `import'
> `each'
> top_level'
> Nicolas MICHEL
> "Foreman users" group.
> email to foreman-users+unsubscribe@googlegroups.com.
> Visit this group at http://groups.google.com/group/foreman-users.
