I have a fresh, manually installed Cent OS 7 system.
On this I wanted to install Foreman 1.15.
The system is not integrated to cooperate DNS, but local DNS resolution via
/etc/hosts and hostname was setuped correctly.
EPEL and Fasttrack was already enabled earlier, in addition to this
puppetlabs-pc1 was installed (yum -y install
https://yum.puppetlabs.com/puppetlabs-release-pc1-el-7.noarch.rpm) and also
the Foreman repo (yum -y install
https://yum.theforeman.org/releases/1.15/el7/x86_64/foreman-release.rpm) as
per Quickstart guide.
The following REPOs are enabled:
[root@hostname1 ~]# yum repolist
repo id repo name
status
base/7/x86_64 CentOS-7 - Base
9,363
centos-sclo-rh/x86_64 CentOS-7 - SCLo rh
5,545
centos-sclo-sclo/x86_64 CentOS-7 - SCLo sclo
403
epel/x86_64 Extra Packages for Enterprise
Linux 7 - x86_64 11,787
extras/7/x86_64 CentOS-7 - Extras
380
fasttrack/7/x86_64 CentOS-7 - fasttrack
0
foreman/x86_64 Foreman 1.15
407
foreman-plugins/x86_64 Foreman plugins 1.15
277
puppetlabs-pc1/x86_64 Puppet Labs PC1 Repository el 7 -
x86_64 122
updates/7/x86_64 CentOS-7 - Updates
1,851
repolist: 30,135
[root@hostname1 ~]#
I started the interactive installer with default options, nothing was
changed.
Nevertheless an errors is raised:
/Stage[main]/Foreman_proxy::Register/Foreman_smartproxy[hostname1.localdomain]:
Could not evaluate: Exception 504 "Unknown Host" in get
reqsmart_proxies?search=name=%22hostname1.localdomain%22
/usr/share/foreman-installer/modules/foreman/lib/puppet/provider/foreman_resource/rest_v3.rb:89:in
rescue in request' /usr/share/foreman-installer/modules/foreman/lib/puppet/provider/foreman_resource/rest_v3.rb:71:in
request'
/usr/share/foreman-installer/modules/foreman/lib/puppet/provider/foreman_smartproxy/rest_v3.rb:6:in
proxy' /usr/share/foreman-installer/modules/foreman/lib/puppet/provider/foreman_smartproxy/rest_v3.rb:13:in
id'
/usr/share/foreman-installer/modules/foreman/lib/puppet/provider/foreman_smartproxy/rest_v3.rb:17:in
exists?' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/property/ensure.rb:81:in
retrieve'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/type.rb:1070:in
retrieve' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/type.rb:1098:in
retrieve_resource'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/resource_harness.rb:300:in
from_resource' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/resource_harness.rb:20:in
evaluate'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:230:in
apply' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:246:in
eval_resource'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:163:in
call' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:163:in
block (2 levels) in evaluate'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:387:in block in thinmark' /opt/puppetlabs/puppet/lib/ruby/2.1.0/benchmark.rb:294:in
realtime'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:386:in thinmark' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:163:in
block in evaluate'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/graph/relationship_graph.rb:118:in
traverse' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:154:in
evaluate'
/usr/share/gems/gems/kafo-2.0.0/modules/kafo_configure/lib/puppet/parser/functions/add_progress.rb:30:in
evaluate_with_trigger' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/resource/catalog.rb:222:in
block in apply'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/log.rb:155:in
with_destination' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/report.rb:142:in
as_logging_destination'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/resource/catalog.rb:221:in
apply' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:171:in
block in apply_catalog'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:224:in block in benchmark' /opt/puppetlabs/puppet/lib/ruby/2.1.0/benchmark.rb:294:in
realtime'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:223:in
benchmark' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:170:in
apply_catalog'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:343:in
run_internal' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:221:in
block in run'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/context.rb:65:in
override' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet.rb:294:in
override'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:195:in
run' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:350:in
apply_catalog'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:274:in
block in main' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/context.rb:65:in
override'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet.rb:294:in override' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:225:in
main'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:170:in
run_command' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application.rb:358:in
block in run'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:542:in
exit_on_fail' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application.rb:358:in
run'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/command_line.rb:132:in
run' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/command_line.rb:72:in
execute'
/opt/puppetlabs/puppet/bin/puppet:5:in <main>' Wrapped exception: 504 "Unknown Host" /opt/puppetlabs/puppet/lib/ruby/2.1.0/net/http/response.rb:119:in
error!'
/opt/puppetlabs/puppet/lib/ruby/2.1.0/net/http/response.rb:128:in value' /opt/puppetlabs/puppet/lib/ruby/2.1.0/net/http.rb:915:in
connect'
/opt/puppetlabs/puppet/lib/ruby/2.1.0/net/http.rb:863:in do_start' /opt/puppetlabs/puppet/lib/ruby/2.1.0/net/http.rb:852:in
start'
/opt/puppetlabs/puppet/lib/ruby/2.1.0/net/http.rb:1375:in request' /opt/puppetlabs/puppet/lib/ruby/gems/2.1.0/gems/oauth-0.5.1/lib/oauth/consumer.rb:161:in
request'
/usr/share/foreman-installer/modules/foreman/lib/puppet/provider/foreman_resource/rest_v3.rb:76:in
request' /usr/share/foreman-installer/modules/foreman/lib/puppet/provider/foreman_smartproxy/rest_v3.rb:6:in
proxy'
id' /usr/share/foreman-installer/modules/foreman/lib/puppet/provider/foreman_smartproxy/rest_v3.rb:17:in
exists?'
retrieve' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/type.rb:1070:in
retrieve'
retrieve_resource' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/resource_harness.rb:300:in
from_resource'
evaluate' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:230:in
apply'
eval_resource' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:163:in
call'
block (2 levels) in evaluate' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:387:in
block in
thinmark'
/opt/puppetlabs/puppet/lib/ruby/2.1.0/benchmark.rb:294:in realtime' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:386:in
thinmark'
block in evaluate' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/graph/relationship_graph.rb:118:in
traverse'
evaluate' /usr/share/gems/gems/kafo-2.0.0/modules/kafo_configure/lib/puppet/parser/functions/add_progress.rb:30:in
block in apply' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/log.rb:155:in
with_destination'
as_logging_destination' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/resource/catalog.rb:221:in
apply'
block in apply_catalog' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:224:in
block in
benchmark'
/opt/puppetlabs/puppet/lib/ruby/2.1.0/benchmark.rb:294:in realtime' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:223:in
benchmark'
apply_catalog' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:343:in
run_internal'
block in run' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/context.rb:65:in
override'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet.rb:294:in override' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:195:in
run'
apply_catalog' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:274:in
block in main'
override'
main' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:170:in
run_command'
block in run' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:542:in
exit_on_fail'
run' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/command_line.rb:132:in
run'
execute' /opt/puppetlabs/puppet/bin/puppet:5:in
<main>'
Failed to call refresh: Exception 504 "Unknown Host" in
get/v2/smart_proxies?search=name=%22hostname1.localdomain%22
Exception 504 "Unknown Host" in get request to:
https://cxs=name=%22hostname1.localdomain%22
request'
id'
retrieve'
/usr/share/foreman-installer/modules/foreman/lib/puppet/type/foreman_smartproxy.rb:53:in
refresh' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/event_manager.rb:147:in
process_callback'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/event_manager.rb:34:in
block in process_events' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/event_manager.rb:119:in
block in queued_events'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/event_manager.rb:118:in
each' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/event_manager.rb:118:in
queued_events'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/event_manager.rb:33:in
process_events' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:247:in
eval_resource'
realtime'
block in evaluate'
evaluate'
block in apply'
realtime'
apply_catalog'
block in run'
override'
apply_catalog'
override'
main'
block in run'
run'
execute'
error!'
connect'
start'
request'
proxy'
exists?'
retrieve' /usr/share/foreman-installer/modules/foreman/lib/puppet/type/foreman_smartproxy.rb:53:in
refresh'
process_callback' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/event_manager.rb:34:in
block in queued_events' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/event_manager.rb:118:in
each'
queued_events' /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/event_manager.rb:33:in
process_events'
call'
block in
thinmark'
thinmark'
traverse'
with_destination'
apply'
block in
benchmark'
benchmark'
run_internal'
override'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet.rb:294:in `
