During the upgrade of Foreman(2.0.3 -> 2.1.4) and katello (3.15 -> 3.16) i got the following error:
warning: /etc/foreman-installer/scenarios.d/foreman-proxy-content-answers.yaml created as /etc/foreman-installer/scenarios.d/foreman-proxy-content-answers.yaml.rpmnew
warning: /etc/foreman-installer/scenarios.d/katello-answers.yaml created as /etc/foreman-installer/scenarios.d/katello-answers.yaml.rpmnew
/etc/foreman-installer/scenarios.d/katello.migrations/200605154320-dont-use-pulpcore-rpm-on-upgrades.rb:9:in block (2 levels) in load_migrations': undefined method
’ for true:TrueClass (NoMethodError)
from /opt/theforeman/tfm/root/usr/share/gems/gems/kafo-4.1.0/lib/kafo/migrations.rb:25:in instance_eval' from /opt/theforeman/tfm/root/usr/share/gems/gems/kafo-4.1.0/lib/kafo/migrations.rb:25:in
block (2 levels) in load_migrations’
from /opt/theforeman/tfm/root/usr/share/gems/gems/kafo-4.1.0/lib/kafo/migration_context.rb:10:in instance_eval' from /opt/theforeman/tfm/root/usr/share/gems/gems/kafo-4.1.0/lib/kafo/migration_context.rb:10:in
execute’
from /opt/theforeman/tfm/root/usr/share/gems/gems/kafo-4.1.0/lib/kafo/migrations.rb:38:in block in run' from /opt/theforeman/tfm/root/usr/share/gems/gems/kafo-4.1.0/lib/kafo/migrations.rb:35:in
each’
from /opt/theforeman/tfm/root/usr/share/gems/gems/kafo-4.1.0/lib/kafo/migrations.rb:35:in run' from /opt/theforeman/tfm/root/usr/share/gems/gems/kafo-4.1.0/lib/kafo/configuration.rb:302:in
run_migrations’
from /opt/theforeman/tfm/root/usr/share/gems/gems/kafo-4.1.0/lib/kafo/kafo_configure.rb:64:in initialize' from /opt/theforeman/tfm/root/usr/share/gems/gems/clamp-1.1.2/lib/clamp/command.rb:132:in
new’
from /opt/theforeman/tfm/root/usr/share/gems/gems/clamp-1.1.2/lib/clamp/command.rb:132:in run' from /opt/theforeman/tfm/root/usr/share/gems/gems/kafo-4.1.0/lib/kafo/kafo_configure.rb:162:in
run’
from /sbin/foreman-installer:8:in `’
warning: %post(foreman-installer-katello-1:2.1.4-1.el7.noarch) scriptlet failed, exit status 1
Non-fatal POSTIN scriptlet failure in rpm package 1:foreman-installer-katello-2.1.4-1.el7.noarch
the same error shows, when running foreman-installer manually afterwards.
successful run of foreman-installer after upgrade
foreman 2.1.4
katello 3.16
centos 7
