> I'm having a problem provisioning all EC2 servers, and can't find what
> the problem is. I created the compute resources successfully, and the
> instance launches successfully, but I receive the following an error
> – http://pastebin.com/YV5ErwG5 … I also tried recreating the
> compute resource, and tried with multiple new hosts to no avail. The
> debug messages that seem the most interesting are:
> 1.
> connecting to ssh-agent
> 2.
> could not connect to ssh-agent
> I retrieved the private key from the key_pairs table (also verified
> the sql is calling the correct one), and was able to ssh in just fine.
> I did receive the following warning when sshing to the IP rather than
> the hostname, although I'm unsure if that would cause a problem:
> > Address 50.19.5.206 maps to
> ec2-50-19-5-206.compute-1.amazonaws.com, but this does not map back to
> the address - POSSIBLE BREAK-IN ATTEMPT!
> Additionally, I wrote a small ruby script to reproduce, but wasn't
> able to. The script I wrote is:
> require 'rubygems'
> require 'net/ssh'
> keys = ["~/id_rsa"]
> Net::SSH.start('50.19.5.206', 'root', :keys => keys, :verbose =>
> :debug) do |ssh|
> # do nothing
> end
> and it gave me this output: http://pastebin.com/BPJJUqvG
> Notice how it uses the same
> key (35:97:c3:25:6b:e1:46:6d:f5:e7:dd:d7:c3:2b:26:2a), but succeeds
> this time.
> I'm on Centos 6.3, using foreman-1.0.0-0.6.el6.noarch from the foreman
> repo http://yum.theforeman.org/development/el6/i386
> Any help would be appreciated.
Are you sure the ami you try to ssh to allows root user login?
Any chance you can grab the instance logs?
Ohad
