I'm trying to upgrade my foreman installation from using Puppet 3 to
Puppet 4.
System: Ubuntu 14.04 LTS with Foreman 1.12 and Puppet 3.
I have upgraded to 1.12 without any noticeable problems.
I'm using the instructions here:
http://projects.theforeman.org/projects/foreman/wiki/Upgrading_from_Puppet_3_to_4
Step 1 seems to work without a problem but step 2 does not work.
After I have ran step 2 without --noop I get a non-working install.
I'm using the install repository from puppet.com but after running
foreman-install it looks like Puppet 4 gets uninstalled and then
reinstalled using Ubuntu-puppet. At least it looks like that when
listing with dpkg --list. It looks like parts of the foreman
installation is also removed, like foreman-installer.
(Luckily I'm able to roll back to a working configuration)
Anyone seen anything like this? Anything I could try to help debug this
problem?
Yours,
Roger
> Hello,
> Puppet 4.
> Upgrading from Puppet 3 to 4 - Foreman
The installer command was missing --reset-puppet-client-package which
should prevent Puppet 3 being reinstalled.
> problem?
I've updated the instructions and run through them again - it seems to
work now. Thanks for the feedback.
On 13/07/16 21:42, Roger Mårtensson wrote:
Dominic Cleal
dominic@cleal.org
Thank you. I
I do still get some errors regarding puppetmaster-common. Why it
This is what I get when running:
foreman-installer --puppet-server-implementation=puppetserver
–reset-foreman-client-ssl-ca --reset-foreman-client-ssl-cert
–reset-foreman-client-ssl-key --reset-foreman-puppet-home
–reset-foreman-puppet-ssldir --reset-foreman-server-ssl-ca
–reset-foreman-server-ssl-cert --reset-foreman-server-ssl-chain
–reset-foreman-server-ssl-crl --reset-foreman-server-ssl-key
–reset-foreman-websockets-ssl-cert --reset-foreman-websockets-ssl-key
–reset-foreman-proxy-puppet-ssl-ca
–reset-foreman-proxy-puppet-ssl-cert
–reset-foreman-proxy-puppet-ssl-key --reset-foreman-proxy-puppetdir
–reset-foreman-proxy-ssl-ca --reset-foreman-proxy-ssl-cert
–reset-foreman-proxy-ssl-key --reset-foreman-proxy-ssldir
–reset-foreman-puppet-home --reset-puppet-autosign
–reset-puppet-client-package --reset-puppet-codedir
–reset-puppet-configtimeout --reset-puppet-dir --reset-puppet-logdir
–reset-puppet-rundir --reset-puppet-ssldir --reset-puppet-vardir
–reset-puppet-server-common-modules-path
–reset-puppet-server-default-manifest-path --reset-puppet-server-dir
–reset-puppet-server-envs-dir --reset-puppet-server-external-nodes
–reset-puppet-server-jruby-gem-home
–reset-puppet-server-puppetserver-dir
–reset-puppet-server-ruby-load-paths --reset-puppet-server-ssl-dir -v
[ERROR 2016-07-14 10:59:30 verbose] Execution of '/usr/bin/apt-get -q -y
-o DPkg::Options::=–force-confold install puppetmaster-common' returned
100: Reading package lists…
[ INFO 2016-07-14 10:59:30 verbose] Building dependency tree…
[ INFO 2016-07-14 10:59:30 verbose] Reading state information…
[ INFO 2016-07-14 10:59:30 verbose] Some packages could not be installed.
This may mean that you have
[ INFO 2016-07-14 10:59:30 verbose] requested an impossible situation or if
you are using the unstable
[ INFO 2016-07-14 10:59:30 verbose] distribution that some required
packages have not yet been created
[ INFO 2016-07-14 10:59:30 verbose] or been moved out of Incoming.
[ INFO 2016-07-14 10:59:30 verbose] The following information may help to
resolve the situation:
[ INFO 2016-07-14 10:59:30 verbose] The following packages have unmet
dependencies:
[ INFO 2016-07-14 10:59:30 verbose] puppetmaster-common : Depends:
puppet-common (= 3.4.3-1ubuntu1.1)
[ INFO 2016-07-14 10:59:30 verbose] E: Unable to correct problems, you have
held broken packages.
/Stage[main]/Puppet::Server::Install/Package[puppetmaster-common]/ensure:
change from purged to present failed: Execution of '/usr/bin/apt-get -q -y
dependencies:
-o DPkg::Options::=–force-confold install puppetmaster' returned 100:
dependencies:
[ INFO 2016-07-14 10:59:30 verbose] puppetmaster : Depends:
puppetmaster-common (= 3.4.3-1ubuntu1.1) but it is not going to be installed
2016-07-14 9:43 GMT+02:00 Dominic Cleal :
I’m trying to upgrade my foreman installation from using Puppet 3 to
Puppet 4.
I’m using the instructions here:
I’m using the install repository from puppet.com but after running
problem?
I’ve updated the instructions and run through them again - it seems to
Dominic Cleal
dominic@cleal.org
"Foreman users" group.
> Thank you. I
> /Stage[main]/Puppet::Server::Install/Package[puppetmaster-common]/ensure: change
> from purged to present failed: Execution of '/usr/bin/apt-get -q -y -o
I can only think of a couple of reasons it might try to install this
Puppet 3 era package:
- The agent is still version 3 - ensure you upgraded (step 1) and are
using Puppet 4 from puppet-agent.
- A parameter's overridden, try adding --reset-puppet-server-package
On 14/07/16 10:34, Roger Martensson wrote:
Dominic Cleal
dominic@cleal.org
Thank you again. Suggestion number 2 was the one that worked for me.
When looking at the installed packages (using dpkg --list) I see no
ubuntu-related packages only older Puppet 3 puppetmasterpackages (not
installed, but RC and not purged). I did try to purge the old puppetmaster
packages but the error was still there.
2016-07-14 11:42 GMT+02:00 Dominic Cleal :
Thank you. I
change
from purged to present failed: Execution of ‘/usr/bin/apt-get -q -y -o
DPkg::Options::=–force-confold install puppetmaster-common’ returned
- A parameter’s overridden, try adding --reset-puppet-server-package
Did notice one more thing. The foreman-reports ruby-file didn't seem to be
installed when running foreman-installer. should it?
It was easy to fix but I believe that the foreman-installer used to do this?
https://theforeman.org/manuals/1.12/index.html#3.5.4PuppetReports
2016-07-14 12:53 GMT+02:00 Roger Martensson :
2016-07-14 11:42 GMT+02:00 Dominic Cleal dominic@cleal.org:
Thank you. I
change
It still does, it should be installed to
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/reports/foreman.rb
when using Puppet Server.
On 14/07/16 13:05, Roger Martensson wrote:
> 2016-07-14 12:53 GMT+02:00 Roger Martensson >:
> 2016-07-14 11:42 GMT+02:00 Dominic Cleal >:
> > Thank you. I
> > DPkg::Options::=--force-confold install puppetmaster-common' returned
> > 100: Reading package lists...
> 1. The agent is still version 3 - ensure you upgraded (step 1)
> and are
> 2. A parameter's overridden, try adding
> (not installed, but RC and not purged). I did try to purge the old
> puppetmaster packages but the error was still there.
> be installed when running foreman-installer. should it?
Dominic Cleal
dominic@cleal.org
In my case it didn't get installed at all. I had to manually install it in
the reports directory… Then it started to work again.
(This was after running the "puppet 4-upgrade-foreman-installer)
2016-07-14 14:16 GMT+02:00 Dominic Cleal :
Did notice one more thing. The foreman-reports ruby-file didn’t seem to
this?
When I upgraded my production environment I noticed that foreman.rb-reports
was inserted. So I guess something wasn't right with my test environment.
What I did notice with both my environments was that I needed to change the
paths found in /etc/sudoers.d/foreman-proxy.
2016-07-14 14:23 GMT+02:00 Roger Martensson :
2016-07-14 14:16 GMT+02:00 Dominic Cleal dominic@cleal.org:
to
this?
In my case it didn’t get installed at all. I had to manually install it
in the reports directory… Then it started to work again.
