We have some problem which might need your help when we use the foreman
discovery , and it is listed below:
The operating environment:
Foreman version 1.6.0
Foreman-proxy version 1.6.0
Foreman discovery version 1.3.0
Ovirt image version 0.5.0-1
Ruby version 1.9.3p484
When we boot a server from* PEX and load it to discovery image, then
find it in discovery hosts* in foreman web page, dhcp records already
exists after we summit all these. The following error comes out after we
click ack and then overwrite.
undefined method `boot_filename' for nil:NilClass
If you feel this is an error with Foreman itself, please open a new issue
with Foreman ticketing system, You would probably need to attach the Full
trace and relevant log entries.
NoMethodError
undefined method boot_filename' for nil:NilClass app/models/concerns/orchestration/dhcp.rb:60:in
dhcp_attrs'
app/models/concerns/orchestration/dhcp.rb:16:in dhcp_record' app/models/concerns/orchestration/dhcp.rb:140:in
dhcp_conflict_detected?'
app/models/concerns/orchestration.rb:47:in valid?' app/models/concerns/foreman/sti.rb:29:in
save_with_type'
app/models/taxonomy.rb:44:in block in no_taxonomy_scope' app/models/taxonomy.rb:51:in
block (2 levels) in as_taxonomy'
app/models/concerns/foreman/thread_session.rb:148:in as_location' app/models/taxonomy.rb:50:in
block in as_taxonomy'
app/models/concerns/foreman/thread_session.rb:113:in as_org' app/models/taxonomy.rb:49:in
as_taxonomy'
app/models/taxonomy.rb:43:in no_taxonomy_scope' app/models/concerns/foreman/thread_session.rb:33:in
clear_thread'
lib/middleware/catch_json_parse_errors.rb:9:in `call'
logļ¼
Operation FAILED: undefined method boot_filename' for nil:NilClass /usr/share/foreman/app/models/concerns/orchestration/dhcp.rb:60:in
dhcp_attrs'
/usr/share/foreman/app/models/concerns/orchestration/dhcp.rb:16:in
dhcp_record' /usr/share/foreman/app/models/concerns/orchestration/dhcp.rb:142:in
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:504:in
_run__2186145019037043531__validation__210935129444102558__callbacks' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:405:in
__run_callback'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:385:in
_run_validation_callbacks' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:81:in
run_callbacks'
/opt/rh/ruby193/root/usr/share/gems/gems/activemodel-3.2.8/lib/active_model/validations/callbacks.rb:53:in
run_validations!' /opt/rh/ruby193/root/usr/share/gems/gems/activemodel-3.2.8/lib/active_model/validations.rb:194:in
valid?'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/validations.rb:69:in
valid?' /usr/share/foreman/app/models/concerns/orchestration.rb:47:in
valid?'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/validations.rb:77:in
perform_validations' /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/validations.rb:50:in
save'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/attribute_methods/dirty.rb:22:in
save' /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/transactions.rb:241:in
block (2 levels) in save'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/transactions.rb:295:in
block in with_transaction_returning_status' /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/connection_adapters/abstract/database_statements.rb:192:in
transaction'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/transactions.rb:208:in
transaction' /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/transactions.rb:293:in
block in save' /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/transactions.rb:252:in
rollback_active_record_state!'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/transactions.rb:240:in
save' /usr/share/foreman/app/models/concerns/foreman/sti.rb:29:in
save_with_type'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/persistence.rb:216:in
block in update_attributes' /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/transactions.rb:295:in
transaction' /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/transactions.rb:208:in
transaction'
with_transaction_returning_status' /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/persistence.rb:214:in
update_attributes'
/opt/rh/ruby193/root/usr/share/gems/gems/foreman_discovery-1.3.0/app/controllers/discovered_hosts_controller.rb:72:in
block in update' /usr/share/foreman/app/models/taxonomy.rb:44:in
block in
no_taxonomy_scope'
/usr/share/foreman/app/models/taxonomy.rb:51:in block (2 levels) in as_taxonomy' /usr/share/foreman/app/models/concerns/foreman/thread_session.rb:148:in
as_location'
/usr/share/foreman/app/models/taxonomy.rb:50:in block in as_taxonomy' /usr/share/foreman/app/models/concerns/foreman/thread_session.rb:113:in
as_org'
/usr/share/foreman/app/models/taxonomy.rb:49:in as_taxonomy' /usr/share/foreman/app/models/taxonomy.rb:43:in
no_taxonomy_scope'
/opt/rh/ruby193/root/usr/share/gems/gems/foreman_discovery-1.3.0/app/controllers/discovered_hosts_controller.rb:71:in
update' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/implicit_render.rb:4:in
send_action'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/base.rb:167:in
process_action' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/rendering.rb:10:in
process_action'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/callbacks.rb:18:in
block in process_action' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:549:in
block (3 levels) in
_run__1838916945586311741__process_action__3825693022177244652__callbacks'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:215:in
block in _conditional_callback_around_6945' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:326:in
around'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:310:in
_callback_around_1823' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:214:in
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:537:in
block (2 levels) in _run__1838916945586311741__process_action__3825693022177244652__callbacks' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:215:in
block in _conditional_callback_around_6944'
/usr/share/foreman/app/models/concerns/foreman/thread_session.rb:33:in
clear_thread' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:214:in
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:426:in
block in _run__1838916945586311741__process_action__3825693022177244652__callbacks' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:215:in
block in _conditional_callback_around_6943'
around' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:310:in
_callback_around_13'
_conditional_callback_around_6943' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:414:in
__run_callback' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:385:in
_run_process_action_callbacks'
run_callbacks' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/callbacks.rb:17:in
process_action'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/rescue.rb:29:in
process_action' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/instrumentation.rb:30:in
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/notifications.rb:123:in
block in instrument' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/notifications/instrumenter.rb:20:in
instrument'
instrument' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/instrumentation.rb:29:in
process_action'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/params_wrapper.rb:207:in
process_action' /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/railties/controller_runtime.rb:18:in
process_action'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/base.rb:121:in
process' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/abstract_controller/rendering.rb:45:in
process'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal.rb:203:in
dispatch' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal/rack_delegation.rb:14:in
dispatch'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_controller/metal.rb:246:in
block in action' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/routing/route_set.rb:73:in
call'
dispatch' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/routing/route_set.rb:36:in
call'
/opt/rh/ruby193/root/usr/share/gems/gems/journey-1.0.4/lib/journey/router.rb:68:in
block in call' /opt/rh/ruby193/root/usr/share/gems/gems/journey-1.0.4/lib/journey/router.rb:56:in
each'
call' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/routing/route_set.rb:600:in
call'
/opt/rh/ruby193/root/usr/share/gems/gems/apipie-rails-0.2.5/lib/apipie/extractor/recorder.rb:97:in
call' /opt/rh/ruby193/root/usr/share/gems/gems/apipie-rails-0.2.5/lib/apipie/middleware/checksum_in_headers.rb:27:in
call'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/best_standards_support.rb:17:in
call' /opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/etag.rb:23:in
call'
/opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/conditionalget.rb:35:in
call' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/head.rb:14:in
call'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/params_parser.rb:21:in
call' /usr/share/foreman/lib/middleware/catch_json_parse_errors.rb:9:in
call'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/flash.rb:242:in
call' /opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/session/abstract/id.rb:205:in
context'
/opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/session/abstract/id.rb:200:in
call' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/cookies.rb:339:in
call'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/query_cache.rb:64:in
call' /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/connection_adapters/abstract/connection_pool.rb:473:in
call'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/callbacks.rb:28:in
block in call' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/callbacks.rb:405:in
_run__4295328971200225218__call__210935129444102558__callbacks'
_run_call_callbacks'
run_callbacks' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/callbacks.rb:27:in
call'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/remote_ip.rb:31:in
call' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/debug_exceptions.rb:16:in
call'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/show_exceptions.rb:56:in
call' /opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/rack/logger.rb:26:in
call_app'
/opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/rack/logger.rb:16:in
call' /opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/request_id.rb:22:in
call'
/opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/methodoverride.rb:21:in
call' /opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/runtime.rb:17:in
call'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/cache/strategy/local_cache.rb:72:in
call' /opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/lock.rb:15:in
call'
/opt/rh/ruby193/root/usr/share/gems/gems/actionpack-3.2.8/lib/action_dispatch/middleware/static.rb:62:in
call' /opt/rh/ruby193/root/usr/share/gems/gems/rack-cache-1.2/lib/rack/cache/context.rb:136:in
forward'
/opt/rh/ruby193/root/usr/share/gems/gems/rack-cache-1.2/lib/rack/cache/context.rb:143:in
pass' /opt/rh/ruby193/root/usr/share/gems/gems/rack-cache-1.2/lib/rack/cache/context.rb:155:in
invalidate'
/opt/rh/ruby193/root/usr/share/gems/gems/rack-cache-1.2/lib/rack/cache/context.rb:71:in
call!' /opt/rh/ruby193/root/usr/share/gems/gems/rack-cache-1.2/lib/rack/cache/context.rb:51:in
call'
/opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/engine.rb:479:in
call' /opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/application.rb:223:in
call'
/opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/railtie/configurable.rb:30:in
method_missing' /opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/builder.rb:134:in
call'
/opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/urlmap.rb:64:in
block in call' /opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/urlmap.rb:49:in
each'
call' /usr/lib/ruby/gems/1.8/gems/passenger-4.0.42/lib/phusion_passenger/rack/thread_handler_extension.rb:74:in
process_request'
/usr/lib/ruby/gems/1.8/gems/passenger-4.0.42/lib/phusion_passenger/request_handler/thread_handler.rb:141:in
accept_and_process_next_request' /usr/lib/ruby/gems/1.8/gems/passenger-4.0.42/lib/phusion_passenger/request_handler/thread_handler.rb:109:in
main_loop'
/usr/lib/ruby/gems/1.8/gems/passenger-4.0.42/lib/phusion_passenger/request_handler.rb:448:in
`block (3 levels) in start_threads'
Rendered common/500.html.erb (13.6ms)
Completed 500 Internal Server Error in 1169ms (Views: 22.2ms |
ActiveRecord: 20.2ms)
Cache read:
https://eg-foreman.nd.cmgame.com/discovered_hosts/mac005056adbfc1/edit?
<https://eg-foreman.nd.cmgame.com/discovered_hosts/mac005056adbfc1/edit?>
I find a similar case in http://projects.theforeman.org(Bug #5701) , but no
solution's been given, pls help us to solve it, thanks a lot!!
