**Problem:
- How can i setup Foreman/Katello on a system with 2 Interfaces (2 separate Subnets/VLAN) to only let systems install via a specific interface(eth0,10.112.0.0/16) ?
I have already defined eth0 als foreman-proxy-dhcp-interface as parameter for forman-installer and defined the dhcp-proxy-gateway and range - initrd.img and vmlinuz are 0 byte -> no boot
i replaced both files with the ones from the centos 7.4 image but now i get errors fetching the kickstart
**Expected outcome:being able to install system on a specific LAN Subnet
**Foreman and Proxy versions:1.20.1
**Foreman and Proxy plugin versions:Katello 3.10
for the 2nd issue i’m getting this error in the proxy.log:
2019-01-18T08:55:58 0a888188 [E] Failed to retrieve provision template for {“token”=>“1be9bc1b-74e7-48ac-bacf-4c8781c48daf”, “splat”=>, “captures”=>[“provision”], “kind”=>“provision”}: Error retrieving provision for {“token”=>“1be9bc1b-74e7-48ac-bacf-4c8781c48daf”, :url=>“http://vm8109.muc.baag:8000”} from vm8109.muc.baag: Net::HTTPNotFound
i assume , that the url should be changed to the IP where the installation should take place on
logs
