I have a proxy configured do to template proxying. The capability is
reported against the smart proxy in the Foreman UI and I can use curl to
fetch the templates but when the grub config is written out it contains a
URL to the master server. I have to manually edit the file to point to the
proxy instead. I've run the proxy in debug but can't see anything to
indicate why this.
Any pointers on where I can look to get to the bottom of this?
Is TFTP feature turned on the proxy? It's the decision point to use it.
My Lord we need to fix this.
LZ
On Wed, May 10, 2017 at 11:42 AM, wrote:
> Hi,
> indicate why this.
> I'm running Katello 3.3/Foreman 1.14.3.
> Thanks,
> Alan
> "Foreman users" group.
> email to foreman-users+unsubscribe@googlegroups.com.
You are using Katello, so it also depends on what Environment are you
in. Environments are associated to particular Capsules, therefore if
you are installing from Env that is not on any Capsule, Foreman will
fallback to itself.
LZ
> Hi,
> indicate why this.
> Thanks,
> Alan
the
proxy instead. I’ve run the proxy in debug but can’t see anything to
indicate why this.
Then do Refresh features in the Foreman UI page, it needs to have it
in Foreman database. Before you click, check if it was present or not.
LZ
On Thu, May 11, 2017 at 3:16 PM, Alan Griffiths wrote:
> TFTP is enabled. A curl on host:9090/features returns
> ["dhcp","logs","pulpnode","puppet","templates","tftp"]
>> LZ
>> > Hi,
>> > a
>> > the
>> > indicate why this.
>> > Thanks,
>> > Alan
>> > Groups
>> > an
>> Later,
>> Lukas @lzap Zapletal
>> You received this message because you are subscribed to a topic in the
>> Google Groups "Foreman users" group.
>> To unsubscribe from this topic, visit
>> https://groups.google.com/d/topic/foreman-users/4yfpjz03kY0/unsubscribe.
>> To unsubscribe from this group and all its topics, send an email to
to
contains
a
the
indicate why this.
