i try to install a server (sl6.1 x86_64) with foreman (vmware pxe +
unattended kickstart).
I can create the host in foreman, the server boot via pxe and get the
installer via tftp.
after booting into the installer i get the normal installer menu to
choose the language.
if i spoof the ip from the host with http://…/?spoof=x.x.x.x, the
kickstart looks good, but the installer don't know about it.
any ideas?
rgds f0
Watch your smart-proxy log during the boot process.
Things to check for:
foreman-proxy user is able to execute "puppet cert"
foreman-proxy user is able to write to /etc/puppet/autosign.conf
foreman-proxy user is able to write to /var/lib/puppet/ssl/ca/inventory.txt
You have the following in your sudoers file: (update puppet path to your environment)
Defaults:foreman !requiretty
foreman-proxy ALL = NOPASSWD: /opt/puppet/bin/puppet
Defaults:foreman-proxy !requiretty
I am assuming your using puppet 2.6+. If not you need to make sure puppetca is accessible to foreman-proxy and in the sudoers file.
You should be running foreman-proxy as the foreman-proxy user. If not do the following:
chown -R foreman-proxy:foreman-proxy /usr/share/foreman-proxy (or whatever path your using)
Corey Osman
corey@logicminds.biz
Green I.T and Datacenter Automation Specialist
installer via tftp.
kickstart looks good, but the installer don’t know about it.
any ideas?
rgds f0
To unsubscribe from this group, send email to foreman-users+unsubscribe@googlegroups.com.
For more options, visit this group at http://groups.google.com/group/foreman-users?hl=en.
hm i have disabled puppetca for this proxy , is this really needed to
install a server via kickstart
rgds f0
> Corey Osman
> co...@logicminds.biz
> > Hi,
> > installer via tftp.
> > if i spoof the ip from the host withhttp://.../?spoof=x.x.x.x, the
> > any ideas?
> > rgds f0
> > You received this message because you are subscribed to the Google Groups "Foreman users" group.
> > To post to this group, send email to foreman-users@googlegroups.com.
> > For more options, visit this group athttp://groups.google.com/group/foreman-users?hl=en.
> Hi,
under settings --> foreman settings, you can disable the manage_puppetca option.
Ohad
On Fri, Oct 28, 2011 at 7:23 PM, f0 wrote:
> rgds f0
>> Corey Osman
>> > Hi,
>> > installer via tftp.
>> > any ideas?
>> > rgds f0
yes puppetca was the problem…thx
> > Hi,
> Ohad
> > rgds f0
> >> Corey Osman
> >> > Hi,
> >> > installer via tftp.
> >> > any ideas?
> >> > rgds f0
