Is anyone using atomic to be provisioned via satellite 6.2.10 ?
While provisioning i am getting this error " [atomic] ImportError: cannot import name OSTree"
My image tag is 7.3.2
Anyone aware of this ? Also after successful provision do i need to apply puppet configurarion to configure DNS,NTP and other stuffs how puppet works in that or what meathod is approprite to configure it.
Are you using on-demand download policy for kickstart or ostree?
Have you added both kickstart and ostree into the same content view
which is in use?
LZ
On Thu, Jul 27, 2017 at 8:18 PM, Unix SA wrote:
> Hello,
> Thanks,
> DJ
> To unsubscribe from this group and stop receiving emails from it, send an email to foreman-users+unsubscribe@googlegroups.com.
One more thing i want to ask is, what is recommended way for doing post
configuration of Atomic host, for example DNS,NTP, authentication … can
anyone guide me on this please?
I think we can not install puppet for doing post configuration.
DJ
On Monday, 31 July 2017 13:44:43 UTC+5:30, Lukas Zapletal wrote:
> Dhaval, do you have a case opened?
> which is in use?
> LZ
> On Thu, Jul 27, 2017 at 8:18 PM, Unix SA <d.jo...@gmail.com > > wrote:
> > Hello,
> > Thanks,
> > DJ
> an email to foreman-user...@googlegroups.com .
> > To post to this group, send email to forema...@googlegroups.com
> Later,
> Lukas @lzap Zapletal
Atomic is essentially a RHEL with some volumes mounted as read-only,
excluding /etc or /var. So you can configure all things the usual way
if you prefer by modifying /etc configuration files. There are some
special things to do, for example configuring Docker and storage for
it (/etc/sysconfig/docker-storage-setup).
Atomic includes nice ad-hoc configuration management interface called
Cockpit, you can easily access it via your web browser and set all of
the most important configuration values or directly start containers
on it. For more info go to:
On Mon, Jul 31, 2017 at 11:09 AM, Unix SA wrote:
> Hi,
> it does work now, it works with > 7.3 OS, Thanks.
> configuration of Atomic host, for example DNS,NTP, authentication .. can
> Thanks,
> DJ
>> which is in use?
>> LZ
>> > Hello,
>> > Thanks,
>> > DJ
>> > an email to foreman-user...@googlegroups.com.
>> > To post to this group, send email to forema...@googlegroups.com.
>> Later,
Basically i want to automate all the configuration, similar to RHEL7
installation where i run puppet after installing OS so it configures my OS.
Is that cloud-init is same ? I am not sure if i can configure all INFRA
services usimg cockpit or add it in kickstart or other config managememt
tools.
Appriciate your time in helping me to understand this concept of
customization in automic.
DJ
Hello, glad to hear you had it working.
> Hi,
> Thanks,
> DJ
>> which is in use?
>> LZ
>> > Hello,
puppet
>> > Thanks,
>> > DJ
>> Later,
To be honest, configuration management is not my domain, someone else
might know better. I don't know if puppet is even available for
Atomic, what could work is Ansible which ssh into hosts and has
self-hosting capability (if Python is installed which I assume it is).
Cockpit is not for automation, it's rather for ad-hoc configuration as I wrote.
LZ
On Mon, Jul 31, 2017 at 11:44 AM, Unix SA wrote:
> Thanks,
> tools.
> Thanks,
> DJ
> - if you prefer by modifying /etc configuration files. There are some
> https://access.redhat.com/articles/2772861
> https://access.redhat.com/documentation/en-us/red_hat_enterprise_linux_atomic_host/7/html-single/installation_and_configuration_guide/
> https://www.projectatomic.io/docs/quickstart/
>> Hi,
>> Thanks,
>> DJ
>>> which is in use?
>>> LZ
>>> > Hello,
>>> > puppet
>>> > Thanks,
>>> > DJ
>>> Later,
> Later,
Thanks, may be some has experice with atomic post customization can help,
because this is important step for us, to configure DNS, NTP,
authentication using LDAP and so on after provisioning of atomic os.
wrote.
LZ
> Thanks,
OS.
> tools.
> Thanks,
> DJ
>> Hi,
>> Thanks,
>> DJ
>>> which is in use?
>>> LZ
>>> > Hello,
>>> > puppet
>>> > Thanks,
>>> > DJ
>>> Later,
> Later,
