I have foreman with auto-discovery running fine, but am now running into
problems when trying to provision the discovered host.
When hitting the SUBMIT button in the Provision-Step, I get some errors
regarding the templates, that seems to be cause by an error with the
interface:
"Some of the interfaces are invalid. Please check the table below."
I do not find any error in the settings, and no error is shown/marked.
I get no direct error in the logs, just lots of tracebacks. Seems to be
after a DHCP reservation is/should be made. I can provide the full log,
if necessary.
> 2017-03-22 12:34:48 34998ab8 [app] [I] Create DHCP reservation for mac5254006a460b.kvm-52:54:00:6a:46:0b/192.168.125.22
> 2017-03-22 12:34:48 34998ab8 [app] [I] Add DNS A record for mac5254006a460b.kvm/192.168.125.22
> 2017-03-22 12:34:48 34998ab8 [app] [I] Add DNS PTR record for 192.168.125.22/mac5254006a460b.kvm
> 2017-03-22 12:34:49 34998ab8 [templates] [I] Rendering template 'PXELinux global default'
> 2017-03-22 12:34:49 34998ab8 [templates] [I] Rendering template 'pxelinux_chainload'
> 2017-03-22 12:34:49 34998ab8 [templates] [I] Rendering template 'pxelinux_discovery'
> 2017-03-22 12:34:49 34998ab8 [app] [W] Unable to render PXELinux template 'PXELinux global default': undefined method each' for nil:NilClass > > NoMethodError: undefined methodeach' for nil:NilClass
> > /opt/theforeman/tfm/root/usr/share/gems/gems/safemode-1.2.4/lib/safemode.rb:58:in bind' > > /opt/theforeman/tfm/root/usr/share/gems/gems/safemode-1.2.4/lib/safemode.rb:51:ineval'
> > /opt/theforeman/tfm/root/usr/share/gems/gems/safemode-1.2.4/lib/safemode.rb:51:in `eval'
Is this a known error in 1.14.2? Anything I can do to debug this? Any
information I can supply to help look for the root cause?
Thanks in advance.
Johannes
Johannes Kastl
Linux Consultant & Trainer
Tel.: +49 (0) 151 2372 5802
Mail: kastl@b1-systems.de
B1 Systems GmbH
Osterfeldstraße 7 / 85088 Vohburg / http://www.b1-systems.de
GF: Ralph Dehner / Unternehmenssitz: Vohburg / AG: Ingolstadt,HRB 3537
Have you changed the template PXELinux global default? Compare against
LZ
On Wed, Mar 22, 2017 at 12:42 PM, Johannes Kastl wrote:
> Hi guys,
> interface:
> if necessary.
>> 2017-03-22 12:34:49 34998ab8 [app] [W] Unable to render PXELinux template 'PXELinux global default': undefined method `each' for nil:NilClass
>> > NoMethodError: undefined method `each' for nil:NilClass
>> > /opt/theforeman/tfm/root/usr/share/gems/gems/safemode-1.2.4/lib/safemode.rb:58:in `bind'
> Thanks in advance.
> Johannes
> Johannes Kastl
> B1 Systems GmbH
> To unsubscribe from this group and stop receiving emails from it, send an email to foreman-users+unsubscribe@googlegroups.com.
> errors regarding the templates, that seems to be cause by an error
> with the interface:
I could solve this issue.
My foreman instance is installed on CentOS 7. So I automatically got a
CentOS 7.3.x Operation System in Foreman.
I had made my tests with a Ubuntu OS that I had clicked together in the
GUI. And with it I run into this error.
I tried the provisioning with CentOS, and it tried to install CentOS
without any interface errors.
So it had to be an error with my put-together Ubuntu. I deleted it and
added it again, and I think I was using the wrong template for "PXELinux
template". Now it is set to "Preseed Default PXELinux" and I can
provision without getting an error.
So, for the next one running into this: Check your templates!
Johannes
Johannes Kastl
B1 Systems GmbH
>> It is the step after that, when provisioning the host, that fails.
> I am attaching a screen shot of the error (I hope it gets through to
> the list).
Is there anything I can do to debug this further? Any more logs?
Anything in the settings I should have a look at?
Is there a way to get foreman to actually say, what the problem is with
the interface? What exactly it is, that is disturbing foreman?
This is rendering foreman unusable for my usecase, so it is kind of
urgent that I get this running.
Johannes
Johannes Kastl
B1 Systems GmbH
I just set up a new instance of foreman, which also has working
discovery, but shows this error. And no, I do not get any more specific
error messages.
Please, can someone help solving this?
Johannes
Johannes Kastl
B1 Systems GmbH
> error messages.
> Johannes
> Johannes Kastl
> B1 Systems GmbH
