I am struggeling to provision my host with debian 10. I have multiple issues and need a helping hand to find the way:
I am using these templates:
PXELinux template Template: Preseed default PXELinux
Finish template Template: Preseed default finish
Provisioning template Template: Preseed default
I am using the default debian mirror installation medium.
Currently my machines is discovered, I can create it in foreman and the machine reboots into the os installer. After some minutes the installation shows me:
┌────────────────┤ [!!] Download installer components ├─────────────────┐
│ No kernel modules were found. This probably is due to a mismatch │
│ between the kernel used by this version of the installer and the │
│ kernel version available in the archive. │
│ If you’re installing from a mirror, you can work around this problem │
│ by choosing to install a different version of Debian. The install │
│ will probably fail to work if you continue without kernel modules. │
│ Continue the install without loading kernel modules? │
If I choose yes, the installation fails at a later point and if I choose no I get into an endless circle, i.e. get the message again. I think it cannot load the components correctly.
First question: Is this a debian problem or a foreman problem?
Second question: Is this related to the foreman version I am using?
I did some research on this topic and there are some posts about this from 2014-2016 (pretty old). These posts basically say there is a version mismatch between the installer and the available kernel. Because of that I wanted to try to use a cdrom iso, from which I know is working. I unpacked the iso to my disk (foreman machine). My idea was to make apache serve these files and add an installation medium to foreman like “http://localhost/…”.
When I did this the host failed to pxe boot (initrd not found). I had a look into the tftp directory: The initrd file had 0 bytes size. I had a look here: PXE booting: Could not find kernel image
I was not able to convince apache to list the directory content. I tried adding “Indexes” to the Options of /etc/apache2/sites-enabled/05-foreman.conf and /etc/apache2/sites-enabled/05-foreman-ssl.conf. But the directory content is not listed. (I did reload and restart apache).
Third question: How do I use an ISO (unpacked) as installation medium?
Debian 10 is installed on the host.
Foreman: 2.0.0
debian 10
As I said in the beginning, I need some directions on where to go from here.
Thank you.
