I am fairly new to foreman.
Using katello 2.4, I installed foreman, created product repositories for
CenOS 7.
Installation kicksoff fine. It pulls the templates OK but as it starts
installing the OS, it stops with errors:
"The following software marked for installation has errors. This is likely
caused by an error with your installation source"
Operating System and Installation Media was pre-created when I synched
CentOS repositories from mirror list.
VM installation console prints "VirtualBox_test_foreman_provision-1.png"
capture first then "VirtualBox_test_foreman_provision-2.png"
Hi
I ended up reinstalling the foreman/katello server.
Re-created centos7 repos.
This time around I also created a content view and published it as opposed to just using default library while creating a new host to provision.
I had other issues with domain creation and adding created domain to new host to be built but at the end was able to get it to work.
