when i add this code
<% if @host.location == "TEST" -%>
lang de_DE.UTF-8
keyboard de
<% end -%>
to the Provisioning Templates then i get the following error
There was an error rendering the KN Kickstart Default template: undefined
method '==' for Safemode::Jail (Location)
But when I print this var, it works!
<%= @host.location %>
Could you help me!.
Ist this a bug?
I'm using Foreman 1.3 on CentOS 6.4
Locations and Organizations is configuerd and enabled
If that doesn't work or hits the same error, try disabling
"safemode_render" under More>Settings. (Note, this means code execution
protection is disabled in your templates.)
On 11/11/13 07:22, PAF wrote:
> Hi,
> lang de_DE.UTF-8
> keyboard de
> <% end -%>
> undefined method '==' for Safemode::Jail (Location)
> Could you help me!.
> Ist this a bug?
Am Montag, 11. November 2013 09:41:49 UTC+1 schrieb Dominic Cleal:
> > Hi,
> > lang de_DE.UTF-8
> > keyboard de
> > <% end -%>
> > Could you help me!.
> > Ist this a bug?
> Try doing this:
> <% if @host.location.to_s == "TEST" -%>
> Dominic Cleal
> Red Hat Engineering
