I've run into the above error and found what seemed to be a work around
here:
https://access.redhat.com/solutions/2773751
- Convert the image Template into the VM.
- Edit the "vmx" file and comment / remove the below lines.
bios.hddOrder
bios.bootOrder
- Convert the VM into the template again.
or
- Take a backup and then edit the file create_vm.rb.
cp /opt/theforeman/tfm/root/usr/share/gems/gems/fog-vsphere*/lib/fog/vsphere/requests/compute/create_vm.rb /opt/theforeman/tfm/root/usr/share/gems/gems/fog-vsphere*/lib/fog/vsphere/requests/compute/create_vm.rb_backup
vi /opt/theforeman/tfm/root/usr/share/gems/gems/fog-vsphere*/lib/fog/vsphere/requests/compute/create_vm.rb
22 vm_cfg[:firmware] = attributes[:firmware] if attributes.key?(:firmware)
23 #vm_cfg[:bootOptions] = boot_options(attributes) if attributes.key?(:boot_order) || attributes.key?(:boot_retry) # WORKAROUND
24 resource_pool = if attributes[:resource_pool] && attributes[:resource_pool] != ‘Resources’
katello-service restart
I did both and still receive the error with Foreman 1.15.1 with VMware
ESXi, 6.5.0, 5969303. The template was created from a VM I built using
foreman if that has any effect.
So, follow up to this. It seems once you make the changes you need to
rebuild the VM you use as an image that will use the new changes. The boot
order parts are no longer present. Once I rebuilt a VM and then used that
as the image I could then use that image template to build others.
http://projects.theforeman.org/issues/14160
TLDR: its a bug in vmware that they may or may not fix, I couldn't get a straight answer out of my vmware contacts. A workaround is implemented in fog-vsphere that should go into 1.16 but there was a regression that still needs to be addressed (https://github.com/fog/fog-vsphere/pull/109).
Greetings
Klaas Demter
ATIX - The Linux & Open Source Company
www.atix.de
----- Ursprüngliche Mail -----
Von: "Mike Wilson"
An: "Foreman users"
Gesendet: Freitag, 8. September 2017 01:14:48
Betreff: [foreman-users] "Provisioning using VMWare template fails with error "configSpec.bootOptions.bootOrder""
I’ve run into the above error and found what seemed to be a work around
here:
- Edit the “vmx” file and comment / remove the below lines.
bios.hddOrder
bios.bootOrder
or
So it's not muddy, the bit I am refering to here is this changes you make
to the "/opt/theforeman/tfm/root/usr/share/gems/gems/fog-vsphere*/
lib/fog/vsphere/requests/compute/create_vm.rb" file. Once that's done and
you rebuild a new VM that VM will not have the order bits and when you
convert to template that should work as image.
