With pulp 2.18.1 GA, pulp’s celery stack dependencies now explicitly conflict with the versions in epel. This has repercussions in katello/foreman as well, any time an upgrade happens.
This was done because of [0], which was causing issues with certain aspects of pulp server due to regressions in celery 4.2.
We’ve attempted a few ways to solve the issue, and landed in the state we are in, causing big ugly conflicts when you install/upgrade packages without intervention. This seemed to be the most effective way to both prevent a bad state, and to convey to the end user of the bad state.
To get around this the following packages need to be excluded from epel somehow:
People have had success with excluding those packages explicitly from epel.
You can also install yum-plugin-priorities and set priorty=2 for pulp’s repo (or any number less than 99, the default priority) and it will pull any packages in pulp’s repo over others instead.
We’ve had similar issues in the past and updated the katello-repos rpm
to require yum-priorities and set the priority automatically. I think
we need to do this again otherwise every user is going to hit this.
Looks like this fix is possibly not working properly for katello nightlies, which are failing with the following error:
File "/bin/yum", line 29, in <module>
yummain.user_main(sys.argv[1:], exit_code=True)
File "/usr/share/yum-cli/yummain.py", line 375, in user_main
errcode = main(args)
File "/usr/share/yum-cli/yummain.py", line 239, in main
(result, resultmsgs) = base.buildTransaction()
File "/usr/lib/python2.7/site-packages/yum/__init__.py", line 1198, in buildTransaction
(rescode, restring) = self.resolveDeps()
File "/usr/lib/python2.7/site-packages/yum/depsolve.py", line 893, in resolveDeps
CheckDeps, checkinstalls, checkremoves, missing = self._resolveRequires(errors)
File "/usr/lib/python2.7/site-packages/yum/depsolve.py", line 1025, in _resolveRequires
(checkdep, missing, errormsgs) = self._processReq(po, dep)
File "/usr/lib/python2.7/site-packages/yum/depsolve.py", line 350, in _processReq
CheckDeps, missingdep = self._requiringFromTransaction(po, requirement, errormsgs)
File "/usr/lib/python2.7/site-packages/yum/depsolve.py", line 703, in _requiringFromTransaction
pkgresults = self._compare_providers(pkgs, requiringPo,req=needname)
File "/usr/lib/python2.7/site-packages/yum/depsolve.py", line 1618, in _compare_providers
bestnum = max(pkgresults.values())
ValueError: max() arg is an empty sequence
@tbrisker This appears to be an issue with me not propagating the entire fix from 2.18 to the master branch of pulp-packaging, as we were more focused on fixing the 2.18 stale repos.
This should be resolved now for nightly as well, and apologies for the hiccups.
