Pulpcore 3.16 repo issue
Trying to sync Index of /pulpcore/3.16/el8/x86_64 fails quickly…
Errors:
null value in column “context” violates not-null constraint
DETAIL: Failing row contains (ee41473a-dc09-4ca9-9203-6f3dcf411674, pulpcore, el8, 31620220309215204, null, x86_64, [{“platform”: [“el8”], “python38”: [“3.8”]}], [“ansible-lint-0:5.0.8-3.el8.noarch”, "createrepo_c-0:0.17.7-4.1…, f).
Trying the same for Index of /pulpcore/3.17/el8/x86_64 appears to be working fine
Is there an issue with the repo content in the 3.16 version?
Correct, I think the modules.yaml metadata in this repository is wrong, it should have a context set.
To be honest though I’m not sure why the 3.17 repo isn’t unsyncable in the same way - it appears to have the same problem.
Yeah, they should both have the same bug right now.
this should fix it once merged and the repo re-generated using it
thanks for spotting!
Thanks guys, and yes the 3.17 repo had the same problem but it took much longer to fail sync. Appreciate your help.
⁣Get BlueMail for Android ​
the above PR got merged and deployed and 3.16 pulpcore repo was re-published (3.17 not yet)
would you mind kicking off a sync on your side, to see if this fixed things for you?
(3.17 got published with the changes too)
Hi Evgeni,
Completed a sync successfully of the 2.16 repo, thanks again for your help.
Regards,
Steve
Thanks again for catching this and testing!
Sorry to necro the thread, but I think I’m seeing what looks like the same error in the katello 4.4 repo for at least the last couple of days:
null value in column "context" violates not-null constraint
DETAIL:  Failing row contains (8d8eeeeb-8599-485a-88f6-940a287e25c8, katello, el8, 40420220309174543, null, x86_64, [{"foreman": ["el8"], "pki-core": []}], ["foreman-proxy-content-0:4.4.0-0.3.rc2.el8.noarch", "katello-0:..., f).
@mhjacks that’s absolutely correct.
It will be fixed the next time the 4.4 repo is published, as it’s driven by the same piece of code.
Hi Evgeni, the sync now works fine. Thanks very much for your help.
