puppet agent --test
returns
[root@host ~]# puppet agent --test
Warning: Unable to fetch my node definition, but the agent run will continue:
Warning: SSL_connect returned=1 errno=0 state=error: certificate verify failed: [self signed certificate in certificate chain for /CN=Puppet Root CA: a441f9721f4df7]
Info: Retrieving pluginfacts
Error: /File[/var/lib/puppet/facts.d]: Failed to generate additional resources using 'eval_generate': SSL_connect returned=1 errno=0 state=error: certificate verify failed: [self signed certificate in certificate chain for /CN=Puppet Root CA: a441f9721f4df7]
Error: /File[/var/lib/puppet/facts.d]: Could not evaluate: Could not retrieve file metadata for puppet://proxy.example.org/pluginfacts: SSL_connect returned=1 errno=0 state=error: certificate verify failed: [self signed certificate in certificate chain for /CN=Puppet Root CA: a441f9721f4df7]
Wrapped exception:
Running puppet agent
CentOS 7
This worked before. But obviously there is a problem with the self-signed cert? How can I check or fix this?
