Hi All.
Refering to this bug:
http://projects.theforeman.org/issues/5692
I'm not able to remove unused and removed puppet classes using the
import, also manual is not possible because of the bug above.
How can I solve this ?
Cheers,
Matt
Hi All.
Cheers,
Matt
OK, update… fixed. It seems that Foreman is importing "conflicting"
classes form other modules with the same name (as you copy them over and
edit them half)
