I'm having an issue with the puppet-foreman module that I wanted to
inquire about - I'm not sure whether this is a bug or I'm trying to
use it in an unintended way.
I currently deploy puppet and foreman with passenger on the same host.
As all interaction is being abstracted out to the foreman-proxy
service, I wanted to set up a dev server with all three (so I can
upgrade foreman from 0.2 to 0.3). However, there is a resource
conflict that arises from the current configuration of the
foreman::proxy::puppetca class.
'file { '/etc/puppet/autosign.conf':' is currently defined in both
foreman::proxy::puppetca and in foreman::puppetca, so when both are
applied to the same host, the catalog will not run.
My gut instinct is to remove the entry from foreman::puppetca as this
functionality is clearly intended to be in the proxy. But I didn't
want to go off in the wrong direction, in case the proxy class was
intended to be an override…
A) Let me know if I'm going at this all wrong
B) Let me know if you need a bug report filed
Greg
You are totally right, you should include the ca/tftp classes on your
proxy, from 0.4 (the upcoming version), we would remove the buildin
tftp/ca support - e.g you would need to use a proxy.
Patches to the module itself are welcomed
Ohad
On Mon, Jun 27, 2011 at 6:50 PM, Greg Etling wrote:
> Thanks,
> Greg
> To unsubscribe from this group, send email to foreman-users+unsubscribe@googlegroups.com.
> For more options, visit this group at http://groups.google.com/group/foreman-users?hl=en.
Looking at the repository, you have already committed the changes to
init.pp to remove the includes of foreman::tftp, foreman::puppetca and
foreman::puppetrun (I have a slightly older, modified version of the
module on my systems). That would leave the only commit to be done as
deleting the manifests/puppetca.pp, manifests/puppetrun.pp and
manifests/tftp.pp files as far as I can see it. I've never created a
patch out of git, so if this diff isn't what you are looking for - let
me know how to generate what you need.
diff --git a/foreman/manifests/puppetca.pp b/foreman/manifests/
puppetca.pp
deleted file mode 100644
index 166a7d4..0000000
--- a/foreman/manifests/puppetca.pp
+++ /dev/null
@@ -1,19 +0,0 @@
-class foreman::puppetca {
- file{"/etc/puppet/autosign.conf":
- owner => $foreman_user,
- group => "puppet",
- mode => 644,
- require => User[$foreman_user],
- myline {
- "allow_foreman_to_execute_puppetca":
- file => "/etc/sudoers",
- line => "${foreman_user} ALL = NOPASSWD: /usr/sbin/puppetca";
- "do_not_require_tty_in_sudo":
- line => "Defaults:${foreman_user} !requiretty";
diff --git a/foreman/manifests/puppetrun.pp b/foreman/manifests/
puppetrun.pp
index 4fcf132..0000000
--- a/foreman/manifests/puppetrun.pp
+++ /dev/null
@@ -1,9 +0,0 @@
-class foreman::puppetrun {
- myline {
- "allow_foreman_to_execute_puppetrun":
- line => "${foreman_user} ALL = NOPASSWD: /usr/bin/puppetrun"
diff --git a/foreman/manifests/tftp.pp b/foreman/manifests/tftp.pp
index 66ff85a..0000000
--- a/foreman/manifests/tftp.pp
+++ /dev/null
@@ -1,18 +0,0 @@
-class foreman::tftp {
- $tftp_dir = "${foreman_dir}/tftp"
- file{$tftp_dir:
- mode => 644,
- ensure => directory,
- recurse => true,
- file {"${tftp_dir}/default":
- content => "default local\ntimeout 20\n\nlabel local\nlocalboot
0\n",
- mode => 544, owner => root,
- require => File[$tftp_dir],
On Jun 27, 12:56 pm, Ohad Levy ohadl...@gmail.com wrote:
On Mon, Jun 27, 2011 at 6:50 PM, Greg Etling getl...@stern.nyu.edu wrote:
I’m having an issue with the puppet-foreman module that I wanted to
inquire about - I’m not sure whether this is a bug or I’m trying to
‘file { ‘/etc/puppet/autosign.conf’:’ is currently defined in both
functionality is clearly intended to be in the proxy. But I didn’t
A) Let me know if I’m going at this all wrong
Ohad
Greg
For more options, visit this group athttp://groups.google.com/group/foreman-users?hl=en.
nice work, assuming there is only one commit - try
git format-patch HEAD~1
this would create a git patch (with your user info).
thanks
Ohad
> puppetca.pp
> +++ /dev/null
> @@ -1,19 +0,0 @@
> - mode => 644,
> - myline {
> puppetrun.pp
> +++ /dev/null
> @@ -1,9 +0,0 @@
> - myline {
> +++ /dev/null
> @@ -1,18 +0,0 @@
> - file{$tftp_dir:
> - mode => 644,
> - recurse => true,
> 0\n",
>> > intended to be an override...
>> Patches to the module itself are welcomed :)
>> Ohad
>> > Thanks,
>> > Greg
Do you prefer I email the patch file to you, or post the content here?
Greg
> thanks
> Ohad
> > puppetca.pp
> > +++ /dev/null
> > @@ -1,19 +0,0 @@
> > - mode => 644,
> > - myline {
> > puppetrun.pp
> > +++ /dev/null
> > @@ -1,9 +0,0 @@
> > - myline {
> > +++ /dev/null
> > @@ -1,18 +0,0 @@
> > - file{$tftp_dir:
> > - mode => 644,
> > - recurse => true,
> > 0\n",
> >> Ohad
> >> > Thanks,
> >> > Greg
best in a new ticket
but you can sent it to me as well
Thanks!
Ohad
> Greg
>> thanks
>> Ohad
>> > puppetca.pp
>> > +++ /dev/null
>> > @@ -1,19 +0,0 @@
>> > - mode => 644,
>> > - myline {
>> > puppetrun.pp
>> > +++ /dev/null
>> > @@ -1,9 +0,0 @@
>> > - myline {
>> > +++ /dev/null
>> > @@ -1,18 +0,0 @@
>> > - file{$tftp_dir:
>> > - mode => 644,
>> > - recurse => true,
>> > 0\n",
>> >> Ohad
>> >> > Thanks,
>> >> > Greg
Ohad,
OK, one more issue. In manifests/proxy/tftp.pp there is an 'include
tftp'…which of course makes sense, but without a documented/published tftp
module - I'm unsure which module you are basing this on: internally created,
or from the forge (ghoneycutt-tftp…example42-tftp)? I have yet to
implement a tftp module, so I'm flexible to whatever is available
I
could always re-invent the wheel, but I don't enjoy it!
Greg
> Ohad,
I
thanks, I'll add it to foreman puppet module
Ohad
On Thu, Jun 30, 2011 at 8:24 PM, Greg Etling wrote:
> Thanks,
> Greg
> To view this discussion on the web visit
> https://groups.google.com/d/msg/foreman-users/-/cTi2AYkcqwEJ.
> Ohad,
> documented/published tftp module - I'm unsure which module you are
> basing this on: internally created, or from the forge
> (ghoneycutt-tftp…example42-tftp)? I have yet to implement a tftp
I could always
done - see https://github.com/ohadlevy/puppet-foreman
Ohad
On Thu, 2011-06-30 at 10:24 -0700, Greg Etling wrote:
> Thanks,
> Greg
