After running 'rake katello:reset' on a development server (vagrant up centos7-devel), I am unable to run puppet agent -t
$ sudo puppet agent -t
Warning: Unable to fetch my node definition, but the agent run will continue:
Warning: Error 400 on SERVER: Failed to find katello.example.com via exec: Execution of '/etc/puppet/node.rb katello.example.com' returned 1:
Info: Retrieving pluginfacts
Warning: nmcli (1.0.6) and NetworkManager (1.0.0) versions don't match. Use --nocheck to suppress the warning.
Error: Could not retrieve catalog from remote server: Error 400 on SERVER: Failed when searching for node katello.example.com: Failed to find katello.example.com via exec: Execution of '/etc/puppet/node.rb katello.example.com' returned 1:
Up until a few weeks ago (hard to say specifically) the puppet agent -t would run fine after a reset.
Is there a foreman-installer command I should run after a reset? Or perhaps the vagrant user needs permissions? Or… I don't know!
> Is there a foreman-installer command I should run after a reset? Or perhaps the vagrant user needs permissions? Or... I don't know!
$ sudo /etc/puppet/node.rb katello.example.com
Could not send facts to Foreman: SSL_connect returned=1 errno=0 state=SSLv3 read server certificate B: certificate verify failed
----- Original Message -----
> > continue:
> Can you show the output of manually running:
and restart apache. This crane configuration affects other vhosts it
seems. Ehelms was working on a fix, but i'm not sure about the status
of that or if there is currently a PR open.
-Justin
>>> continue:
> >>> continue:
> >>> exec:
> >>> Use
> >>> Use
> >>> Use
> >>> SERVER:
> >>> perhaps
> You might checking your http config, there's a current dev installer bug
> where crane is configured improperly on a dev install.
> in change these lines
> SSLCertificateFile "/etc/pki/tls/certs/localhost.crt"
> SSLCertificateKeyFile "/etc/pki/tls/private/localhost.key"
> to
> SSLCertificateFile "/etc/pki/katello/certs/katello-default-ca.crt"
> SSLCertificateKeyFile "/etc/pki/katello/private/katello-default-ca.key"
> -Justin
The change missing was in /etc/httpd/conf.d/03-crane.conf
puppet agent -t success
> > >>> continue:
> > >>> exec:
> > >>> Use
> > >>> Use
> > >>> Use
> > >>> SERVER:
> > >>> perhaps
> > > state=SSLv3
> > to
> > -Justin
> Below is already in /etc/httpd/conf.d/05-katello-ssl.conf. Should there be
> something in 05-katello.conf?
> ## SSL directives
> SSLEngine on
> SSLCACertificatePath "/etc/pki/tls/certs"
> SSLCACertificateFile "/etc/pki/katello/certs/katello-default-ca.crt"
> SSLVerifyClient optional
> SSLVerifyDepth 3
> SSLOptions +StdEnvVars
