PuppetCA foreman proxy disabled beacuse of autosign issue
**Problem:Foreman-Proxy puppetCA module does not load due to :autosignfile: feature in puppetca.yml
**Expected outcome:Foreman-Proxy should work with the :autosignfile: feature as described in the documentation
**Foreman and Proxy versions:*Foreman -Version 1.20.1, Foreman-proxy 1.20.1
cat /var/log/foreman-proxy/proxy.log|head -n 10
2018-12-21T16:08:17 [E] Disabling all modules in the group [‘puppetca_hostname_whitelisting’, ‘puppetca’] due to a failure in one of them: Provider ‘puppetca_hostname_whitelisting’ settings conflict with the main plugin’s settings: [:autosignfile]
cat /etc/foreman-proxy/settings.d/puppetca.yml
# PuppetCA management
:enabled: https
:ssldir: /etc/puppetlabs/puppet/ssl
:autosignfile: /etc/puppetlabs/puppet/autosign.conf
logs
I followed the guide: https://www.theforeman.org/manuals/1.20/index.html#4.3.7PuppetCA
It seems that on the foreman-proxy you can configure in puppetca.yml (:use_provider: puppetca_hostname_whitelisting) and configure the autosingfile in puppetca_hostname_whitelisting.yml not in puppetca.yml.
This approach seems to work, I`ll test it to see if the autosign.conf file will be generated on the PuppetCA for the new provisioned host.
Will come back later with more info
You’re right that the guide is outdated. This changed in 1.19.0 but we failed to update the docs. I suppose most people use the installer instead.
@Ade: Do you mind updating our docs? They’re on github: https://github.com/theforeman/theforeman.org/blob/gh-pages/_includes/manuals/1.20/4.3.7_smartproxy_puppetca.md
That would help a lot. Thank you.
Ade, thanks for the tip.
After foreman upgrade (?), PuppetCA didn’t start because value if autosignfile parameter was empty in puppetca_hostname_whitelisting.yml:
:autosignfile:
I set a file path to this parameter and starting PuppetCA is OK.
I have created a pull-request to update the manual
Sorry I saw the email too late, I’ve noticed Dirk already updated them.
Let me know if I can help with anything else.
Cheers,
Ade
