After upgrading from 2.0 to 2.1 one of my proxies fails to start on boot. But if I systemctl restart foreman-proxy
then it starts fine. My other proxy runs fine.
Log from failed start on boot:
2020-07-11T23:38:28 [E] Disabling all modules in the group ['puppetca_http_api', 'puppetca_hostname_whitelisting', 'puppetca'] due to a failure in one of them: File at '/etc/puppetlabs/puppet/ssl/certs/ca.pem' defined in 'puppet_ssl_ca'
parameter doesn't exist or is unreadable
2020-07-11T23:38:28 [E] Disabling all modules in the group ['puppet_proxy_puppet_api', 'puppet'] due to a failure in o
ne of them: File at '/etc/puppetlabs/puppet/ssl/certs/ca.pem' defined in 'puppet_ssl_ca' parameter doesn't exist or is
unreadable
2020-07-11T23:38:28 [I] Successfully initialized 'foreman_proxy'
2020-07-11T23:38:28 [I] Successfully initialized 'logs'
2020-07-11T23:38:28 [E] Unable to load private SSL key. Are the values correct in settings.yml and do permissions allo
w reading?
2020-07-11T23:38:28 [W] Error details for Unable to load private SSL key. Are the values correct in settings.yml and d
o permissions allow reading?: <Errno::ENOENT>: No such file or directory @ rb_sysopen - /etc/puppetlabs/puppet/ssl/private_keys/puppet.XXX.pem
/usr/share/foreman-proxy/lib/launcher.rb:111:in `read'
/usr/share/foreman-proxy/lib/launcher.rb:111:in `load_ssl_private_key'
/usr/share/foreman-proxy/lib/launcher.rb:101:in `https_app'
/usr/share/foreman-proxy/lib/launcher.rb:174:in `launch'
/usr/share/foreman-proxy/bin/smart-proxy:6:in `<main>'
2020-07-11T23:38:28 [E] Error during startup, terminating
2020-07-11T23:38:28 [W] Error details for Error during startup, terminating: <Errno::ENOENT>: No such file or director
The permissions for for the .pem are correct:
# ll /etc/puppetlabs/puppet/ssl/private_keys
total 12
drwxr-x--- 2 puppet puppet 6144 Oct 30 2019 ./
drwxrwx--x 8 puppet puppet 6144 Jul 11 23:39 ../
-rw-r----- 1 puppet puppet 3243 Oct 30 2019 puppet.XXX.pem
# groups foreman-proxy
foreman-proxy : foreman-proxy puppet
The proxy starts on boot.
Foreman: 2.1.0
Proxy: 2.1.0
foreman_bootdisk: 17.0.2
foreman_setup: 6.0.0
Ubuntu 18.04
As above.
