When browsing https://foreman/puppetdb_foreman/nodes i get the error:
undefined method `body’ for nil:NilClass
Full stack trace is:
*ActionView::Template::Error*
**undefined method `body' for nil:NilClass**
/usr/share/foreman/vendor/ruby/2.3.0/gems/puppetdb_foreman-4.0.0/app/views/puppetdb_foreman/nodes/index.html.erb:1:in `_vendor_ruby_______gems_puppetdb_foreman_______app_views_puppetdb_foreman_nodes_index_html_erb__3360266841160862343_70230694056260'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionview-5.1.6/lib/action_view/template.rb:157:in `block in render'
/usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.6/lib/active_support/notifications.rb:168:in `instrument'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionview-5.1.6/lib/action_view/template.rb:352:in `instrument_render_template'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionview-5.1.6/lib/action_view/template.rb:155:in `render'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionview-5.1.6/lib/action_view/renderer/template_renderer.rb:52:in `block (2 levels) in render_template'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionview-5.1.6/lib/action_view/renderer/abstract_renderer.rb:42:in `block in instrument'
/usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.6/lib/active_support/notifications.rb:166:in `block in instrument'
/usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.6/lib/active_support/notifications/instrumenter.rb:21:in `instrument'
/usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.6/lib/active_support/notifications.rb:166:in `instrument'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionview-5.1.6/lib/action_view/renderer/abstract_renderer.rb:41:in `instrument'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionview-5.1.6/lib/action_view/renderer/template_renderer.rb:51:in `block in render_template'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionview-5.1.6/lib/action_view/renderer/template_renderer.rb:59:in `render_with_layout'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionview-5.1.6/lib/action_view/renderer/template_renderer.rb:50:in `render_template'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionview-5.1.6/lib/action_view/renderer/template_renderer.rb:14:in `render'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionview-5.1.6/lib/action_view/renderer/renderer.rb:42:in `render_template'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionview-5.1.6/lib/action_view/renderer/renderer.rb:23:in `render'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionview-5.1.6/lib/action_view/rendering.rb:103:in `_render_template'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/action_controller/metal/streaming.rb:217:in `_render_template'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionview-5.1.6/lib/action_view/rendering.rb:83:in `render_to_body'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/action_controller/metal/rendering.rb:52:in `render_to_body'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/action_controller/metal/renderers.rb:141:in `render_to_body'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/abstract_controller/rendering.rb:24:in `render'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/action_controller/metal/rendering.rb:36:in `render'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/action_controller/metal/instrumentation.rb:44:in `block (2 levels) in render'
/usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.6/lib/active_support/core_ext/benchmark.rb:12:in `block in ms'
/usr/lib/ruby/2.3.0/benchmark.rb:308:in `realtime'
/usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.6/lib/active_support/core_ext/benchmark.rb:12:in `ms'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/action_controller/metal/instrumentation.rb:44:in `block in render'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/action_controller/metal/instrumentation.rb:87:in `cleanup_view_runtime'
/usr/share/foreman/vendor/ruby/2.3.0/gems/activerecord-5.1.6/lib/active_record/railties/controller_runtime.rb:29:in `cleanup_view_runtime'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/action_controller/metal/instrumentation.rb:43:in `render'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/action_controller/metal/implicit_render.rb:33:in `default_render'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/action_controller/metal/basic_implicit_render.rb:4:in `block in send_action'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/action_controller/metal/basic_implicit_render.rb:4:in `tap'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/action_controller/metal/basic_implicit_render.rb:4:in `send_action'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/abstract_controller/base.rb:186:in `process_action'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/action_controller/metal/rendering.rb:30:in `process_action'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/abstract_controller/callbacks.rb:20:in `block in process_action'
/usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.6/lib/active_support/callbacks.rb:108:in `block in run_callbacks'
/usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.6/lib/active_support/callbacks.rb:117:in `block in run_callbacks'
/usr/share/foreman/vendor/ruby/2.3.0/gems/audited-4.8.0/lib/audited/sweeper.rb:14:in `around'
/usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.6/lib/active_support/callbacks.rb:135:in `run_callbacks'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/abstract_controller/callbacks.rb:19:in `process_action'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/action_controller/metal/rescue.rb:20:in `process_action'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/action_controller/metal/instrumentation.rb:32:in `block in process_action'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/action_controller/metal/instrumentation.rb:30:in `process_action'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/action_controller/metal/params_wrapper.rb:252:in `process_action'
/usr/share/foreman/vendor/ruby/2.3.0/gems/activerecord-5.1.6/lib/active_record/railties/controller_runtime.rb:22:in `process_action'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/abstract_controller/base.rb:124:in `process'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionview-5.1.6/lib/action_view/rendering.rb:30:in `process'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/action_controller/metal.rb:189:in `dispatch'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/action_controller/metal.rb:253:in `dispatch'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/action_dispatch/routing/route_set.rb:49:in `dispatch'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/action_dispatch/routing/route_set.rb:31:in `serve'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/action_dispatch/journey/router.rb:50:in `block in serve'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/action_dispatch/journey/router.rb:33:in `each'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/action_dispatch/journey/router.rb:33:in `serve'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/action_dispatch/routing/route_set.rb:844:in `call'
/usr/share/foreman/vendor/ruby/2.3.0/gems/apipie-rails-0.5.14/lib/apipie/static_dispatcher.rb:65:in `call'
/usr/share/foreman/vendor/ruby/2.3.0/gems/apipie-rails-0.5.14/lib/apipie/extractor/recorder.rb:137:in `call'
/usr/share/foreman/vendor/ruby/2.3.0/gems/apipie-rails-0.5.14/lib/apipie/middleware/checksum_in_headers.rb:27:in `call'
/usr/share/foreman/vendor/ruby/2.3.0/gems/rack-2.0.6/lib/rack/etag.rb:25:in `call'
/usr/share/foreman/vendor/ruby/2.3.0/gems/rack-2.0.6/lib/rack/conditional_get.rb:25:in `call'
/usr/share/foreman/vendor/ruby/2.3.0/gems/rack-2.0.6/lib/rack/head.rb:12:in `call'
/usr/share/foreman/vendor/ruby/2.3.0/gems/rack-2.0.6/lib/rack/session/abstract/id.rb:232:in `context'
/usr/share/foreman/vendor/ruby/2.3.0/gems/rack-2.0.6/lib/rack/session/abstract/id.rb:226:in `call'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/action_dispatch/middleware/cookies.rb:613:in `call'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/action_dispatch/middleware/callbacks.rb:26:in `block in call'
/usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.6/lib/active_support/callbacks.rb:97:in `run_callbacks'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/action_dispatch/middleware/callbacks.rb:24:in `call'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/action_dispatch/middleware/debug_exceptions.rb:59:in `call'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/action_dispatch/middleware/show_exceptions.rb:31:in `call'
/usr/share/foreman/vendor/ruby/2.3.0/gems/railties-5.1.6/lib/rails/rack/logger.rb:36:in `call_app'
/usr/share/foreman/vendor/ruby/2.3.0/gems/railties-5.1.6/lib/rails/rack/logger.rb:26:in `call'
/usr/share/foreman/vendor/ruby/2.3.0/gems/sprockets-rails-3.2.1/lib/sprockets/rails/quiet_assets.rb:13:in `call'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/action_dispatch/middleware/remote_ip.rb:79:in `call'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/action_dispatch/middleware/request_id.rb:25:in `call'
/usr/share/foreman/vendor/ruby/2.3.0/gems/rack-2.0.6/lib/rack/method_override.rb:22:in `call'
/usr/share/foreman/vendor/ruby/2.3.0/gems/rack-2.0.6/lib/rack/runtime.rb:22:in `call'
/usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-5.1.6/lib/active_support/cache/strategy/local_cache_middleware.rb:27:in `call'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/action_dispatch/middleware/executor.rb:12:in `call'
/usr/share/foreman/vendor/ruby/2.3.0/gems/actionpack-5.1.6/lib/action_dispatch/middleware/static.rb:125:in `call'
/usr/share/foreman/vendor/ruby/2.3.0/gems/rack-2.0.6/lib/rack/sendfile.rb:111:in `call'
/usr/share/foreman/vendor/ruby/2.3.0/gems/secure_headers-5.0.5/lib/secure_headers/middleware.rb:13:in `call'
/usr/share/foreman/vendor/ruby/2.3.0/gems/railties-5.1.6/lib/rails/engine.rb:522:in `call'
/usr/share/foreman/vendor/ruby/2.3.0/gems/railties-5.1.6/lib/rails/railtie.rb:185:in `public_send'
/usr/share/foreman/vendor/ruby/2.3.0/gems/railties-5.1.6/lib/rails/railtie.rb:185:in `method_missing'
/usr/share/foreman/vendor/ruby/2.3.0/gems/rack-2.0.6/lib/rack/urlmap.rb:68:in `block in call'
/usr/share/foreman/vendor/ruby/2.3.0/gems/rack-2.0.6/lib/rack/urlmap.rb:53:in `each'
/usr/share/foreman/vendor/ruby/2.3.0/gems/rack-2.0.6/lib/rack/urlmap.rb:53:in `call'
/usr/share/foreman/vendor/ruby/2.3.0/gems/rack-2.0.6/lib/rack/handler/webrick.rb:86:in `service'
/usr/lib/ruby/2.3.0/webrick/httpserver.rb:140:in `service'
/usr/lib/ruby/2.3.0/webrick/httpserver.rb:96:in `run'
/usr/lib/ruby/2.3.0/webrick/server.rb:296:in `block in start_thread'
/usr/share/foreman/vendor/ruby/2.3.0/gems/logging-2.2.2/lib/logging/diagnostic_context.rb:474:in `block in create_with_logging_context'
Not sure if it depends on the upgrade from 1.18.
I’m sure i was able to see the page in 1.18, i cannot tell if 1.19 broke it or it broke afterwards (trying to get mco working)
The nodes page
ii foreman 1.19.1-1 amd64 Systems management web interface
ii foreman-compute 1.19.1-1 all metapackage providing fog dependencies for Foreman,
ii foreman-console 1.19.1-1 all metapackage providing console dependencies for Foreman
ii foreman-debug 1.19.1-1 all provides support utility foreman-debug.
ii foreman-ec2 1.19.1-1 all metapackage providing EC2 dependencies for Foreman
ii foreman-openstack 1.19.1-1 all metapackage providing OpenStack dependencies for Foreman
ii foreman-postgresql 1.19.1-1 all metapackage providing PostgreSQL dependencies for Foreman
ii foreman-proxy 1.19.1-1 all RESTful proxies for DNS, DHCP, TFTP, and Puppet
ii foreman-sqlite3 1.19.1-1 all metapackage providing sqlite dependencies for Foreman
ii ruby-hammer-cli-foreman 0.14.0-1 all Foreman commands for Hammer
ii ruby-puppetdb-foreman 4.0.0-1 all Foreman Puppetdb Plugin
no plugins
I think the trace is enough.
Thanks!
