I am trying to use https://pypi.python.org/pypi/python-foreman this
i have installed python 3.4 i have installed python 3.4 on my system which
one is compatible with this api
when i run the script gave me this error
WARNING:root:Api v1 will not be the default in the next version, if you
still want to use it, change the call to explicitly ask for it. Though we
recommend using the new and improved version 2
Sounds like you may have to set the API version you want to use. The
foreman project does not build or maintain this Python library for
interacting with Foreman so I would reach out to that project directly to
ask the question [1].
