Is the qpid-cpp-client-devel package required on Jenkins slaves still?
The infra repo attempts to install it on EL6/7 slaves, but the repo and
package no longer seem to exist:
It's present in EL7 if it's still needed, but I can't see an EL6 source.
Else I'll remove both the repository and package as it's causing errors
on slaves.
It’s present in EL7 if it’s still needed, but I can’t see an EL6 source.
Else I’ll remove both the repository and package as it’s causing errors
on slaves.
I believe this is actually required as now seen by the new katello test
failures:
00:03:32.077 An error occurred while installing qpid_messaging (0.34.1), and Bundler cannot 00:03:32.077 continue. 00:03:32.077 Make sure that gem install qpid_messaging -v '0.34.1' succeeds before 00:03:32.077 bundling. 00:03:32.132 + exit 1
On 08/12/2016 07:48 AM, Dominic Cleal wrote:
> On 12/08/16 12:28, Eric D Helms wrote:
>> Should be good to remove.
> Thanks, I've removed the Yum repo and the package will be left wherever
> it's currently installed.
Restored using that repo for EL6 and base OS for EL7.
> failures:
> *00:03:32.077* An error occurred while installing qpid_messaging (0.34.1), and Bundler cannot
> *00:03:32.077* continue.
> *00:03:32.077* Make sure that `gem install qpid_messaging -v '0.34.1'` succeeds before
> *00:03:32.077* bundling.
> *00:03:32.132* + exit 1
> The EL6 source is now in the copr qpid repo (https://copr.fedorainfracloud.org/coprs/g/qpid/qpid/)
