Rails 4 has_and_belongs_to_many -- locations & organizations
Hi Tom,
Per the discussion on irc regarding the Rails 4 branch, note that there is a separate join table 'locations_organizations' to handle:
class Location < Taxonomy
has_and_belongs_to_many :organizations
class Organization < Taxonomy
has_and_belongs_to_many :locations
The problem you were problem facing is that Rails 4 changes the naming convention of the join table.
has_and_belongs_to_many :organizations, join_table: : locations_organizations
has_and_belongs_to_many :locations, join_table: : locations_organizations
Otherwise it will look for a table ' location_organizations ' (NO 's') and fail.
I would not include the relationship between Location / Organization in taxable_taxonomies.
Joseph
yup. it actually looked for taxonomies_taxonomies, which makes even less
sense…
Thanks, Joseph!
··· On Thursday, December 18, 2014 9:15:25 AM UTC+2, Joseph Magen wrote: > > Hi Tom, > > Per the discussion on irc regarding the Rails 4 branch, note that there is > a separate join table 'locations_organizations' to handle: > > class Location < Taxonomy > > has_and_belongs_to_many :organizations > > > class Organization < Taxonomy > > has_and_belongs_to_many :locations > > > The problem you were problem facing is that Rails 4 changes the naming > convention of the join table. > > > class Location < Taxonomy > > has_and_belongs_to_many :organizations, *join_table: > :locations_organizations* > > > > class Organization < Taxonomy > > has_and_belongs_to_many :locations, *join_table: > :locations_organizations* > > > > Otherwise it will look for a table '*location_organizations*' (NO 's') > and fail. > > I would not include the relationship between Location / Organization in > taxable_taxonomies. > > Joseph > > >
Tom,
Are you sure? I'm pretty sure it would look for locations_organizations and not taxonomies_taxonomies unless I'm missing something.
Joseph
··· ----- Original Message -----
To: foreman-dev@googlegroups.com
Cc: tcaspy@redhat.com
Sent: Monday, December 22, 2014 3:22:15 PM
Subject: [foreman-dev] Re: Rails 4 has_and_belongs_to_many – locations &
organizations
sense…
Thanks, Joseph!
Hi Tom,
a
separate join table ‘locations_organizations’ to handle:
Otherwise it will look for a table ’ location_organizations ’ (NO ‘s’) and
fail.
taxable_taxonomies.
Joseph
"foreman-dev" group.
email to foreman-dev+unsubscribe@googlegroups.com .
For more options, visit https://groups.google.com/d/optout .
