Towards getting more consistency, I wanted to look at making use of the
existing foreman-installer-modulesync [1]. The options that crossed my mind
for accomplishing this:
Fork, update managed_modules.yml and modulesync.yml and keep repo in sync
Maintain repository with custom managed_modules.yml and modulesync.yml
and script to clone foreman-installer-modulesync and add our .yml files to
it locally
Add Katello maintained puppet modules to the list of managed_modules for
complete centralization
One technical limitation is that AFAIK modulesync can only work on one
github namespace. That rules out option 3 for now (unless you move all
katello modules to theforeman).
Maybe start with option 1 and then move on from there? Our experience
with modulesync was that it was quite a big change to implement in
itself (though surely worth it). In general we have few changes to the
modulesync repo so maintaining a fork shouldn't be much effort. When we
do have a change, it is big though. See the linked PRs on 1 and 2
(WIP) for the amount of work.
Another thing to consider is that We also use strict puppet-lint plugins
that should help make the code more future proof. That's a good thing,
but it may require some big changes to get the katello modules to pass.
A fork can allow you to start with fewer checks and then over time use
more.
Option 2 sounds like a lot of manual work that git can help you prevent.
I hope this helps.
On Tue, Mar 17, 2015 at 03:13:43PM -0400, Eric D Helms wrote:
> All,
> 1) Fork, update managed_modules.yml and modulesync.yml and keep repo in sync
> 2) Maintain repository with custom managed_modules.yml and modulesync.yml
> it locally
> 3) Add Katello maintained puppet modules to the list of managed_modules for
> Thoughts?
> > All,
> > existing foreman-installer-modulesync 1. The options that crossed my
> mind
> sync
> to
> > it locally
> for
> > Thoughts?
> I fully support the idea.
> more.
> I hope this helps.
It does, thanks! It occurred to me half way through reading this that we
have a variation that forking would account for as well, namely that we
have dropped 2.7 support (not that we really ever supported it not having
published modules) while you still test for it. The thing I want to prevent
the most is when update X happens to foreman-installer-modulesync it's not
weeks before we notice and update ours as well. I realize I can watch the
repository, but there are so many repositories I watch already I fear it
may get lost.
Eric
On Tue, Mar 17, 2015 at 3:46 PM, Ewoud Kohl van Wijngaarden < ewoud@kohlvanwijngaarden.nl> wrote:
I took an initial stab at this by forking the foreman-installer-modulesync
repository and then opening a PR against it with the necessary changes. For
anyone that has a chance to take a look: https://github.com/Katello/foreman-installer-modulesync/pull/1
Eric
On Tue, Mar 17, 2015 at 4:07 PM, Eric D Helms wrote:
On Tue, Mar 17, 2015 at 3:46 PM, Ewoud Kohl van Wijngaarden < > ewoud@kohlvanwijngaarden.nl> wrote:
All,
mind
sync
modulesync.yml
to
it locally
for
Thoughts?
modulesync repo so maintaining a fork shouldn’t be much effort. When we
that should help make the code more future proof. That’s a good thing,
more.
I hope this helps.
the most is when update X happens to foreman-installer-modulesync it’s not
may get lost.
