When foreman db:migrate tries to run I get an error
"no such file to load – apipie/middleware/checksum_in_headers"
I thought I made this go away but when i try to install on a different
machine the error has come back. The only thing I can think of is the EPEL
repository I have locally may be missing something since it was "cleaned
out" by my trusty assistant.
Here's the full trace:
su - foreman -s /bin/bash -c "RAILS_ENV=production foreman-rake --trace
db:migrate"
(in /usr/share/foreman)
rake aborted!
/usr/lib/ruby/site_ruby/1.8/rubygems/custom_require.rb:31:in
gem_original_require' /usr/lib/ruby/site_ruby/1.8/rubygems/custom_require.rb:31:in
require'
/usr/share/foreman/config/application.rb:2
require'
/usr/share/foreman/Rakefile:1
/usr/lib/ruby/gems/1.8/gems/rake-0.8.7/lib/rake.rb:2382:in load' /usr/lib/ruby/gems/1.8/gems/rake-0.8.7/lib/rake.rb:2382:in
raw_load_rakefile'
/usr/lib/ruby/gems/1.8/gems/rake-0.8.7/lib/rake.rb:2016:in load_rakefile' /usr/lib/ruby/gems/1.8/gems/rake-0.8.7/lib/rake.rb:2067:in
standard_exception_handling'
/usr/lib/ruby/gems/1.8/gems/rake-0.8.7/lib/rake.rb:2015:in load_rakefile' /usr/lib/ruby/gems/1.8/gems/rake-0.8.7/lib/rake.rb:1999:in
run'
standard_exception_handling' /usr/lib/ruby/gems/1.8/gems/rake-0.8.7/lib/rake.rb:1997:in
run'
/usr/lib/ruby/gems/1.8/gems/rake-0.8.7/bin/rake:31
/usr/bin/rake:19:in `load'
/usr/bin/rake:19
Hi Peter,
Are you upgrading skipping a minor version? I see this old thread where
Konstantin had the same problem you're having here in that scenario.
https://groups.google.com/forum/#!topic/foreman-users/EPRhCTomQ1k
Let us know if that helps
> "no such file to load -- apipie/middleware/checksum_in_headers"
> # su - foreman -s /bin/bash -c "RAILS_ENV=production foreman-rake --trace
> db:migrate"
> rake aborted!
> `gem_original_require'
> /usr/lib/ruby/site_ruby/1.8/rubygems/custom_require.rb:31:in `require'
> /usr/lib/ruby/gems/1.8/gems/rake-0.8.7/lib/rake.rb:2382:in `load'
> `raw_load_rakefile'
> /usr/lib/ruby/gems/1.8/gems/rake-0.8.7/lib/rake.rb:2016:in `load_rakefile'
> `standard_exception_handling'
> /usr/lib/ruby/gems/1.8/gems/rake-0.8.7/lib/rake.rb:2015:in `load_rakefile'
> /usr/lib/ruby/gems/1.8/gems/rake-0.8.7/lib/rake.rb:1999:in `run'
> /usr/lib/ruby/gems/1.8/gems/rake-0.8.7/lib/rake.rb:1997:in `run'
> /usr/bin/rake:19
> To unsubscribe from this group and stop receiving emails from it, send an email to foreman-users+unsubscribe@googlegroups.com.
> Visit this group at http://groups.google.com/group/foreman-users.
Daniel Lobato Garcia
@eLobatoss
blog.daniellobato.me
daniellobato.me
Keybase: https://keybase.io/elobato
Actually after going home and getting a good night's sleep and attacking
the issue again this morning I noticed something I overlooked.
Seems the folks in charge of our RHEL Satellite server failed to add the
entitlement for RHSC and Developer's Tools. Now I am waiting for them to
get that done.
Thanks for the reply at any rate.
On Thu, Mar 26, 2015 at 2:59 AM Daniel Lobato Garcia wrote:
Hi Peter,
Konstantin had the same problem you’re having here in that scenario.
EPEL
repository I have locally may be missing something since it was “cleaned
out” by my trusty assistant.
Here’s the full trace:
db:migrate"
rake aborted!
require’
require’
raw_load_rakefile’
standard_exception_handling’
run’
run’
/usr/bin/rake:19:in `load’
/usr/bin/rake:19
Groups “Foreman users” group.
@eLobatoss
daniellobato.me
