Hello - I am new to this community and I need guidance on Red Hat Satellite and I am at a basic level plus with Satellite. Constantly learning.
One of the servers has lost its disk and I need to rebuild that host. I am being told it can be done easily in Satellite. Is there a step by step guide on what to ?
Any guidance is appreciated.
Thank you
Hi @cchauhan I had a look at the Provisioning Hosts guide but did not find any instructions.
Basic procedure (tested on an older Foreman): Go to Hosts > All Hosts, select a host, and click “Build”. In the dialog box, select “Reboot now” and click “Reboot and build”. If might also depend on the compute resource provide and version of Satellite.
