Release notes need a comment on storeconfigs
Will keep thinking of things to add as time allows.
Cheers,
Brian
its documented under the uuid feature (as thats the main issue with it).
Ohad
··· On Fri, Jun 22, 2012 at 1:48 AM, Brian Gupta wrote:
Cheers,
Brian
I do feel that we should mention it in the actual release notes, since
I do feel that having a seperate storeconfigs database is going to
generally be the direction I think we want to move in. (Unless I am
missing something.) Also, since I believe the new ENC script was
released after 0.4, I think we should call it out too. (It's really
great, and most people are likely to miss it unless they are following
things really closely…)
Brian
··· On Fri, Jun 22, 2012 at 12:20 AM, Ohad Levy wrote: > > > On Fri, Jun 22, 2012 at 1:48 AM, Brian Gupta > wrote: >> >> Will keep thinking of things to add as time allows. > > its documented under the uuid feature (as thats the main issue with it). > > Ohad >> >> >> Cheers, >> Brian > >
