Built my test rig with the latest Katello 3.2 release and looking into the
Remote Execution plugin. I can get it working by manually copying the .pub
key into the client's authorized_keys file, but I'm not seeing the key
published via the API as is claimed in the manual:
https://theforeman.org/plugins/foreman_remote_execution/0.3/index.html#2.2RemoteHostsConfiguration
claims
curl https://myproxy.example.com:8443/ssh/pubkey >> ~/.ssh/authorized_keys
is a method for pulling the relevant key onto the host. But I get nothing
back from that URL and can find nothing in the API docs about pubkey. Has
this method been dropped?
Cheers
D
Looking at recently installed machine I can see that the default https port
for smart proxy was changed from 8443 to 9090, check which port your proxy
should listen on with cat /etc/foreman-proxy/settings.yml | grep https_port.
Hope this helps
Adam
key into the client’s authorized_keys file, but I’m not seeing the key
Foreman :: Plugin Manuals.
claims
Cheers
D
"Foreman users" group.
Bingo - 9090 it is. I'll submit a change for the documentation.
> port for smart proxy was changed from 8443 to 9090, check which port your
> proxy should listen on with cat /etc/foreman-proxy/settings.yml | grep
> https_port.
> Hope this helps
> Adam
>> the Remote Execution plugin. I can get it working by manually copying the
>> .pub key into the client's authorized_keys file, but I'm not seeing the key
>> claims
>> nothing back from that URL and can find nothing in the API docs about
>> pubkey. Has this method been dropped?
>> Cheers
>> D
>> Visit this group at https://groups.google.com/group/foreman-users.
Sorry to revive this old thread but the documentation still says port 8443 and port 9090 is the port that works.-> Foreman :: Plugin Manuals
Can someone update the documentation?
Well, the thing is, 8443[1] is the port if you don’t have katello. In the katello scenario the default port moves to 9090[2]. And nothing prevents you from using something completely different.
Also the new docs have this covered properly in Foreman - Managing Hosts and Katello - Managing Hosts
[1] - puppet-foreman_proxy/init.pp at 1e45b6b47cf9357f15dd16a41b241403d480b537 · theforeman/puppet-foreman_proxy · GitHub
[2] - foreman-installer/katello-answers.yaml at develop · theforeman/foreman-installer · GitHub
