Greeting all,
I am very new to Foreman, so my issues could simply be ignorance. Do all
the hosts have to be on the same network for the commands to be successful
using the Remote Execution 0.1 on Foreman 1.10.0-RC-3? When I try to run a
job, they all time out.
1: Exit status: EXCEPTION
2: Error initializing command #
3: Errno::ETIMEDOUT Connection timed out - connect(2)
I am testing out different scenarios to which I need to be able to send
remote commands to devices regardless of what network they are on. I was
running Spacewalk but it wasn't stable on debian based clients. So far my
testing with Foreman has been excellent.
Additionally, when I try to install the Remote Excecution plugin on a
debian based system, regardless of a fresh install or not, I get the
following error:
PG::DuplicateColumn: ERROR: column "version" of relation
"dynflow_schema_info" already exists
I was able to get everything to install properly on a CentOS system, which
is how I am testing the above. What is the appropriate method to report an
issue with a plugin? Since my linux experience is with Debian bases
systems, I would feel more comfortable with getting that working. Again,
please excuse my lack of knowledge.
Thanks!
Carl
> From: "Carl Davis" <carl.davis@inreality.com>
> To: "Foreman users" <foreman-users@googlegroups.com>
> Sent: Monday, November 30, 2015 2:06:35 PM
> Subject: [foreman-users] Remote Execution questions/issue
> Greeting all,
Remote Execution uses SSH, so the particular smart proxy needs to be able
to reach the host on port 22. It sounds like it can't.
> following error:
How are you installing the plugin?
Can you provide more logs? Perhaps the output of foreman-rake db:migrate
and anything that looks interesting in /var/log/foreman.
----- Original Message -----
Thanks!
Carl
"Foreman users" group.
Thanks for the response. Regarding the timeout, I dug further into some of
the logs of the failed attempts and it appears as if they do indeed need to
be on the same network or have a FQDN. My use case is that all the hosts
will be spread all over and sitting on a basic network with no port
forwarding available. Additionally, I will not be able to set a truly
FQDN, A records, etc. I was able to get around it by installing NeoRouter
on the Server and the hosts, then setting the virtual NIC that NeoRouter
configures (nrtap) as the NIC that execution commands are run on. From
there, everything worked as expected.
Regarding the install issues on Debian, I tried two slightly different
methods, but both based off the Plugin Manual found
here: Foreman :: Plugin Manuals My
first attempt was following the Quick Install of Foreman 1.10, enrolled a
few devices to make sure things were working properly, then running
foreman-installer --enable-foreman-plugin-remote-execution
–enable-foreman-plugin-tasks
–enable-foreman-proxy-plugin-remote-execution-ssh
The second attempt was following the Quick Install of foreman and instead
of running just foreman-installer the first time to install foreman, I ran
the above command. There was a third attempt following the Quick Install
followed by the directions for manually installing the plugin. That
resulted in the following error:
ruby-smart-proxy-remote-execution-ssh : Depends: ruby-net-ssh (<= 2.1.0)
but 1:2.6.8-1 is to be installed
Here is the CLI output from the installation, unfortunately I do not recall
if it was the first or second attempt.
root@fedfor:~# foreman-installer --enable-foreman-plugin-remote-execution
Execution of '/usr/bin/apt-get -q -y -o DPkg::Options::=–force-confold
install ruby-smart-proxy-remote-execution-ssh' returned 100: Reading
package lists…
/Stage[main]/Foreman_proxy::Plugin::Remote_execution::Ssh/Foreman_proxy::Plugin[remote_execution_ssh]/Package[ruby-smart-proxy-remote-execution-ssh]/ensure:
change from purged to present failed: Execution of '/usr/bin/apt-get -q -y
-o DPkg::Options::=–force-confold install
ruby-smart-proxy-remote-execution-ssh' returned 100: Reading package
lists…
/Stage[main]/Foreman_proxy::Register/Foreman_smartproxy[fedfor.inreality.com]:
Failed to call refresh: Proxy fedfor.inreality.com cannot be registered
(Could not load data from https://fedfor.inreality.com
Proxy fedfor.inreality.com cannot be registered (Could not load data from
Installing Done
[100%]
There was no foreman-installer.log, but this came from /var/log/syslog
Nov 23 11:27:51 fedfor libapache2-mod-passenger: apache2_invoke: Enable
module passenger
Nov 23 11:27:57 fedfor crontab[5037]: (root) LIST (root)
Nov 23 11:28:05 fedfor puppet-agent[5405]: Reopening log files
Nov 23 11:28:05 fedfor puppet-agent[5405]: Starting Puppet client version
3.8.4
Nov 23 11:28:05 fedfor puppet-agent[5409]: Unable to fetch my node
definition, but the agent run will continue:
Nov 23 11:28:05 fedfor puppet-agent[5409]: Connection refused - connect(2)
Nov 23 11:28:05 fedfor puppet-agent[5409]: (/File[/var/lib/puppet/facts.d])
Failed to generate additional resources using 'eval_generate': Connection
Could not evaluate: Could not retrieve file metadata for
puppet://fedfor.inreality.com/pluginfacts: Connection refused - connect(2)
Nov 23 11:28:05 fedfor puppet-agent[5409]: (/File[/var/lib/puppet/lib])
puppet://fedfor.inreality.com/plugins: Connection refused - connect(2)
Nov 23 11:28:06 fedfor puppet-agent[5409]: Could not retrieve catalog from
remote server: Connection refused - connect(2)
Nov 23 11:28:06 fedfor puppet-agent[5409]: Using cached catalog
Nov 23 11:28:06 fedfor puppet-agent[5409]: Could not retrieve catalog;
skipping run
Nov 23 11:28:06 fedfor puppet-agent[5409]: Could not send report:
Nov 23 11:29:46 fedfor kernel: [ 426.234465] perf samples too long (20057
> 20000), lowering kernel.perf_event_max_sample_rate to 6250
Nov 23 11:30:01 fedfor CRON[6609]: (foreman) CMD ( cd ${FOREMAN_HOME} &&
/usr/sbin/foreman-rake trends:counter >/var/log/foreman/cron.log 2>&1)
Nov 23 11:30:01 fedfor CRON[6610]: (foreman) CMD ( cd ${FOREMAN_HOME} &&
/usr/sbin/foreman-rake ldap:refresh_usergroups >>/var/log/foreman/cron.log
2>&1)
I'll dig back through things and see if there is anything else.
Thanks again!
Carl
> > From: "Carl Davis" <carl....@inreality.com >
> > To: "Foreman users" <forema...@googlegroups.com >
> > Greeting all,
> all
> successful
> run a
> was
> my
> > following error:
> Can you provide more logs? Perhaps the output of `foreman-rake
> db:migrate`,
> which
> an
> Again,
> > Thanks!
> > Carl
> > You received this message because you are subscribed to the Google
> Groups
> > To unsubscribe from this group and stop receiving emails from it, send
> an
> > email to foreman-user...@googlegroups.com .
> > To post to this group, send email to forema...@googlegroups.com
> > Visit this group at http://groups.google.com/group/foreman-users.
> > For more options, visit https://groups.google.com/d/optout.
> Cc: stephen@redhat.com
> Sent: Tuesday, December 1, 2015 3:20:56 PM
> Subject: Re: [foreman-users] Remote Execution questions/issue
The only requirement is Foreman needs to be able reach the host, which is not
the same thing as in the same network. NeoRouter is a VPN? That sounds awfully
overcomplicated.
We determine the IP we connect to in the following order:
- the IP of the interface marked "execution" (there's a checkbox)
- any interface that has a valid IP
- the IP the FQDN resolves to
DNS shouldn't be a requirement if you have an IP set in Foreman for the host.
Also, thanks for the Debian info below, this helps. We haven't had many testers on
Debian since the developers are mostly all Red Hat people, I appreciate you trying
it out! I'll poke around and see what I can figure out.
Execution of ‘/usr/bin/apt-get -q -y -o DPkg::Options::=–force-confold
install ruby-smart-proxy-remote-execution-ssh’ returned 100: Reading
package lists…
change from purged to present failed: Execution of ‘/usr/bin/apt-get -q -y
ruby-smart-proxy-remote-execution-ssh’ returned 100: Reading package
lists…
Installing Done
[100%]
module passenger
3.8.4
Failed to generate additional resources using ‘eval_generate’: Connection
skipping run
2>&1)
I’ll dig back through things and see if there is anything else.
Thanks again!
Carl
From: “Carl Davis” <carl....@inreality.com <javascript:>>
To: “Foreman users” <forema...@googlegroups.com <javascript:>>
Greeting all,
all
successful
run a
was
running Spacewalk but it wasn’t stable on debian based clients. So far
my
to reach the host on port 22. It sounds like it can’t.
following error:
PG::DuplicateColumn: ERROR: column “version” of relation
which
an
Again,
Thanks!
Carl
Groups
an
email to foreman-user...@googlegroups.com <javascript:>.
<javascript:>.
Stephen,
My issue is that these will be devices that sit behind a firewall/router on
some network somewhere in the country. IT departments won't be setting up
any sort of port forwarding to my devices and some will even restrict
inbound connections. My current test setup is a Foreman instance residing
on a DigitalOcean server. I then have 8 or so devices that are disbursed
between my office, my house, and one or two other locations. Those hosts
are just another device on the network, there is no special demilitarized
zone, port forwarding, etc. So the IP address that gets reported back to
Foreman is 192.168.x.x or 10.0.x.x, essentially private IP addresses. As
such, the Forman instance does not know how to get to 192.168.x.x. Again,
I am just coming up to speed on systems like Foreman and Puppet, so I might
be over or under thinking things.
I tinkered with Spacewalk for a little bit and was able to get remote
commands to work, but they only ran when the host reached out to the
Spacewalk server. They did have a process to where you setup OSAD and
Jabber to tell the host that a "message" was waiting for the host and that
it should check in. However, Spacewalk for Debian was not reliable and
where I am excited about Foreman's reliability. Running Spacewalk, if the
device's network connection dropped at any point, it would not check back
in with the server until the device was rebooted. Many of my devices are
going to be Raspberry Pis, which is the reason for Debian support. I need
to check and see if Puppet has any sort of process similar to OSAD/Jabber.
For the moment, that is where NeoRouter comes in. It is a VPN solution,
but it allows for a "LAN-like" network. It's actually very simple. So far
that has allowed me to circumvent any firewall restrictions that might be
put into place. I am open to hearing how other people are getting around
these potential restrictions, I am certainly all for simplicity.
I'm not opposed to getting up to speed on RedHat, but Debian is my comfort
zone.
Thanks again for all the help and patience while I educate myself.
Carl
> > Cc: ste...@redhat.com
> of
> to
> hosts
> NeoRouter
> not
> awfully
> overcomplicated.
> host.
> testers on
> you trying
> > here: http://theforeman.org/plugins/foreman_remote_execution/0.1/ My
> a
> > --enable-foreman-plugin-tasks
> > --enable-foreman-proxy-plugin-remote-execution-ssh
> instead
> ran
> Install
> recall
> > Execution of '/usr/bin/apt-get -q -y -o DPkg::Options::=--force-confold
> > package lists...
> -y
> > -o DPkg::Options::=--force-confold install
> > lists...
> from
> > Installing Done
> > [100%]
> > * Foreman is running at https://fedfor.inreality.com
> > Initial credentials are admin /
> > * Foreman Proxy is running at https://fedfor.inreality.com:8443
> > * Puppetmaster is running at port 8140
> > The full log is at /var/log/foreman-installer/foreman-installer.log
> > module passenger
> version
> > 3.8.4
> connect(2)
> Connection
> connect(2)
> Connection
> from
> > skipping run
> (20057
> > 2>&1)
> > Thanks again!
> > Carl
> > > > Greeting all,
> Do
> > > all
> > > successful
> to
> > > run a
> send
> I
> > > was
> far
> > > my
> able
> a
> > > > following error:
> > > db:migrate`,
> > > which
> report
> > > an
> > > Again,
> > > > Thanks!
> > > > Carl
> > > Groups
> send
> > > an
> Groups
> an
> Stephen,
The way that Foreman can deal with this is you would put a Smart Proxy
in 192.168.x.x network that also has an IP that the foreman can talk to.
It would handle proxying the ssh requests from the Foreman to the
unreachable hosts. You can have many smart proxies.
Spacewalk is a totally different architecture. Your use case might be
supported better by something like Salt whenever we add an execution
provider for it.
Jabber to tell the host that a “message” was waiting for the host and that
where I am excited about Foreman’s reliability. Running Spacewalk, if the
device’s network connection dropped at any point, it would not check back
but it allows for a “LAN-like” network. It’s actually very simple. So far
I’m not opposed to getting up to speed on RedHat, but Debian is my comfort
zone.
Carl
Cc: ste...@redhat.com <javascript:>
of
to
hosts
NeoRouter
not
awfully
overcomplicated.
- the IP of the interface marked “execution” (there’s a checkbox)
DNS shouldn’t be a requirement if you have an IP set in Foreman for the
host.
Also, thanks for the Debian info below, this helps. We haven’t had many
testers on
you trying
it out! I’ll poke around and see what I can figure out.
a
instead
ran
Install
recall
–enable-foreman-plugin-remote-execution
package lists…
-y
lists…
from
Installing Done
[100%]
module passenger
version
3.8.4
connect(2)
Connection
connect(2)
Connection
from
skipping run
(20057
2>&1)
Thanks again!
Carl
Greeting all,
Do
all
successful
to
run a
send
I
was
far
my
able
a
following error:
which
report
an
Again,
Thanks!
Carl
Groups
send
an
<javascript:>.
Groups
an
<javascript:>.
Best Regards,
Stephen Benjamin
Red Hat Engineering
