Remote execution task failures
I can not seem to get a task to run on remote hosts. I either get this auth error (when remote_execution_without_proxy is set to Yes/True and remote_execution_global_proxy to No/False). I have confirmed I can connect to the host via ssh root@100.91.41.184 from command prompt. There is very little logging, even with all debugs on, so I have no idea what commands its attempting or what user/ssh key its trying to use.
If I turn remote_execution_global_proxy to Yes/True, then I get this proxy error. However, the proxy is showing as up, with no errors and does display Dynflow and SSH services in Foreman proxies page.
To be able to run remote execution.
CentOS 7
Foreman 1.17.0
Proxy Version 1.17.0
tfm-rubygem-foreman_remote_execution 1.4.5-2
tfm-rubygem-foreman_remote_execution_core 1.1.0-1
rubygem-smart_proxy_remote_execution_ssh 0.1.5-1
links above
Ended up fixing this. There was no real smoking gun. Just had to keep messing with all the correct settings in the conf files. I think one of the main issues was using localhost instead of 0.0.0.0 (or vice-versa).
Perhaps the docs need a bit of love then? That’s usually the case if there’s not a stand-out bug blocking things :slight_smile:
